Old 04-15-2010, 02:19 PM   #1
Hart_Rod
Hart_Rod's Avatar
Transmission shifting to soon....
My TH350 will shift first through third prior to getting up to 15 mph. Even if you get on it with mild throttle, it shifts really quick and then seems like it's lugging the motor (if you manually shift it, everything works great). I've checked and double checked the vacuum and I have no fluid coming out of the modulator. It has been working fine and just recently started doing this. Could the modulator be stuck or bad? It's a Sid Neal built transmission with less than 2K miles. Thoughts? TIA.
Hart_Rod is offline   Reply With Quote
Old 04-15-2010, 03:18 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Transmission shifting to soon....
some modulator valves are adjustable so you can adjust shifts if memory serves me correctly, I think it adjusts with an allen wrench. but if it just started doing it the valve may be bad. hopefully someone with more knowledge will chime in .
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 04-15-2010, 03:42 PM   #3
beebster
beebster's Avatar
Location: Aurora,Il ..born,raised and still live in the same house
I replace my bad t350 with another (junkyard) turbo 350 and it wouldn't shift at all.
I replaced the vacuum modulator (new at napa for $10 bucks) and then it shifted way too soon just like yours.
so i took off the original vacuum modulator from the bad t350 and it shifted fine.
If not i would have tried another vacuum modulator or gone to the junkyard and pulled a couple to try the different shift points.
seems like the different vacuum modulators all give different shift points
beebster is offline   Reply With Quote
Old 04-15-2010, 07:23 PM   #4
cparman
sharp as a marble
pull the vacuum hose off of the modulator. See if it is adjustable. Remove the governor cover from the drivers side of the trans. I cannot remember ( old fart ) it the cover has a bell wire ( hoop ) or if it has four 1/4 bolts to hold it on. Anyway, after removing the cover, remove the governor. There will be an assembly that is about 3-4 inches long. At the end nearest the cover will be two ' wings' and at the other end will be a nylon gear. The gear can become ' apple cored " thin in the middle. If the gear is that way replace it. it is held on with a roll pin. Should be able to get one from a trans shop, don't know if NAPA carries them. After replacing the gear wash the governor assy, very well with brake clean and work the wings back and forth as you do it.
As for the modulator, IF I REMEMBER, if there is a straight slot screw inside of the vacuum nipple turning it in will make the shifts later.
Do you have the kickdown cable connected to the throttle linkage? needs to be. IIR this will also delay shifts with 1/2 + throttle.
WELL GET TO WORK!!!!!
cparman is offline   Reply With Quote
Old 04-15-2010, 07:57 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
check to see if the kickdown cable came disconnected from the carb. If it has not, then try adjusting it. Make sure it hasn't snapped.
Odds are the modulator is fine. If anything would have changed, it would have gone from shifting fine to not shifting at all.
After inspecting the cable I'd pull the govener and see if it is working properly.
Old 04-15-2010, 09:01 PM   #6
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Kick down Cables x2. I adjusted my cables a few weeks ago because it shifted to early and hardly kick down when I stood on it. Know it does not shift till about 2000 RPM and it kicks down with less than half throttle, it will also hold a gear longer if I am going up hill.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
Old 04-15-2010, 09:13 PM   #7
Hart_Rod
Hart_Rod's Avatar
The kickdown is not hooked up. It hasn't been the entire time that I've had the truck and it just started doing this....
Old 04-15-2010, 09:24 PM   #8
clinebarger
Pull the governor cover and inspect the governor for broken springs.
clinebarger is offline   Reply With Quote
Old 04-15-2010, 09:52 PM   #9
JPCY72
wow I guess im not the only one with this problem i dont have the kick down hooked up either.... mines shifting really early...
JPCY72 is offline   Reply With Quote
Old 04-15-2010, 09:56 PM   #10
davebloomer
davebloomer's Avatar
mine shifts early too with kickdown hooked up. I don't care though as I'm looking for a 700r4
davebloomer is offline   Reply With Quote
Old 04-15-2010, 10:42 PM   #11
Longhorn Man
with no kickdown, it will shift early.
Old 04-15-2010, 10:45 PM   #12
BarryB
BarryB's Avatar
I'll also say check the governor, easy as pie to replace. I had one go bad on me but that was along time ago, can't remember the symptoms though. Oh it was also on a trans that was recently rebuild, sometimes the governors don't get replaced during a rebuild.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-19-2010, 05:10 PM   #13
Hart_Rod
Hart_Rod's Avatar
OK, I figured out the problem and yes, it turned out to be me.... I kinda over thought myself on this one. I was worried about pressurizing the modulator when the motor is boosting. So me being the engineering, pocket protector wearing geek that I can sometimes be (no snide comments required here, ), I installed a one way check valve in the vacuum line. Eureka!!! Problem solved on the boost part. Anyone want guess what new problem this created????
EDIT: I spoke to a very knowledgable tranny guy and he said the kickdown has NO effect on the normal operation of the transmission. He said the only purpose was to drop the transmission down into 2nd. I will however get this connected as soon as I gain a little room underneath the carb enclosure. More to come on that later, .
Old 04-19-2010, 06:55 PM   #14
Longhorn Man
the kickdown does in fact hold the tranny in first and second when you are at wide open throttle, and even at medium throttle to a much lesser extent.
Drive a vehicle around the block with a properly adjusted one, then disconnect it and go for a drive. It will be obviouse.
Old 04-19-2010, 07:41 PM   #15
Hart_Rod
Hart_Rod's Avatar
350 or 400? I'm know transmission expert, I'm just telling you what the man who does it for a living said, .
Old 04-19-2010, 08:29 PM   #16
gonzo6869
gonzo6869's Avatar
I have a TH350 and I can Tell you, when I adjusted, it held the grear longer then it did when it was out of adjustment. I can really notice it in second gear. Oh yeah, it will hold third till the engine blows
72 C-10 Stepper
350/TH350
3.73 in the back
Hooker Comp Headers
Old 04-19-2010, 09:11 PM   #17
Hart_Rod
Hart_Rod's Avatar
What did you adjust? The kickdown or the modulator?
Old 04-19-2010, 09:17 PM   #18
Longhorn Man
the 400 doesn't have a kickdown cable on it.
I've had a tranny rebuild guy tell me the same thing. Had another one tell me that the modulator wouldn't keep a trans from shifting. (while it won't technicly keep it from shifting, if disconnected it'll make it 'hold' the gear till 4500 - 5500 RPM)
We no longer use that guy for obviouse reasons... he was a parts swapper and didn't know how the trans actually worked.
The guy you are talking to may be like him too, or he may be too familiar with late model stuff and has forgotten old school 3 speed GM trannys. They have been out dated for a long time, so it is a possibility.
With the kickdown disconnected, you'll only get 4000 or so RPMs out of first, and then second will only hold on for a moment before going into third. Some call this 'stacked shifting' The kickdown will hold each of the lower 2 gears untill the govonor tells it to shift.
Old 04-19-2010, 09:25 PM   #19
Hart_Rod
Hart_Rod's Avatar
Sounds good to me. As soon as I can figure out a way to hook it up, I'll git R done, .
