Old 04-15-2010, 03:33 PM   #1
Ear Candy
Water temp help!!!
I have a 72 lb 350 2wd just installed new temp sending unit in left side of head between plugs, my gauge seem to work but after about 15 min of driving it pegs to hot. Just to be safe I installed new water pump, thermostat, upper/lower hoses. still same problem gauge gets pegged to H.
I checked my other gauge set and it does the same thing, I have bypassed factory wires etc.. every possible combo i could think of. still no luck. Truck doesnt overheat, drives fine rest of gauges work ok. Its just an old truck and I'd like to know the water temp is okay. any suggestions BEFORE i install a separate gauge?
Ear Candy is offline   Reply With Quote
Old 04-15-2010, 03:44 PM   #2
red71c10
The Red Menace
red71c10's Avatar
Re: Water temp help!!!
It is possible you got a faulty sending unit. It's been known to happen. If the same thing is happening with two different gauges, and you are sure the truck isn't overheating, It might be the unit.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 04-15-2010, 04:19 PM   #3
cdowns
cdowns's Avatar
check the wire to see if it is melted and grounded to the motor that will cause the gauge to peg at hot
Old 04-16-2010, 12:52 AM   #4
AustinScott
AustinScott's Avatar
another thing to think about is air in the system, if a pocket of air gets trapped around the sending unit, the temps will climb quickly. Just to be safe I would get another complete gauge with sending unit and see what the new one reads.
A cheap sunpro from auto zone should work fine.
AustinScott is offline   Reply With Quote
Old 04-16-2010, 06:06 AM   #5
bitchin85
bitchin85's Avatar
sounds like an air pocket to me
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 04-16-2010, 08:21 AM   #6
Ear Candy
Thanks fellas! I flushed it out AGAIN and changed the sending unit, its working great now. so it was probably bad sending unit/air pocket or both.
always the simple sH*t that gets it everytime.
Old 04-16-2010, 09:55 AM   #7
neba
i have tryed 2 sending units and mine still reads hot. what brand did you use? there is a delco sender available for about $25 i may try next.
neba is offline   Reply With Quote
Old 04-22-2010, 10:00 AM   #8
Ear Candy
Both of mine were Delco parts ACD G1852
"I'm not here, and I ain't leavin"
Old 04-22-2010, 10:18 AM   #9
mrbwtie
put a thermometer in the radiator and check coolant temp. also it maybe possible the radiator clogged.
mrbwtie is offline   Reply With Quote
Old 04-22-2010, 03:52 PM   #10
mightyatom
mightyatom's Avatar
I have the same issue even after 3 temp senders, new water pump, thermostat. I have added thread below to tie them together in case others have similar issues. I will update mine once resolved.
http://67-72chevytrucks.com/vboard/s...d.php?t=393670
Jay
{ 1972 Chevrolet C-10 Fleetside, 350 V8, 5.7L. }
mightyatom is offline   Reply With Quote
