Intentionally Left Blank
Custom Offset Steel wheels
Hey guys, I'm looking for some steel wheels that I can put some hubcaps on. I need them about 10 or 12 inches wide with a custom offset. I checked Wheel Vintiques and US Wheel, but they don't have any in 6 lug. I really want to keep the six lug bolt pattern. Any ideas? Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
Re: Custom Offset Steel wheels
Try Stockton Wheels.
DiablosWeldingFabrication
Stockton wheels made mine.
Senior Enthusiast
You might also try RallyAmerica. They've received good press in a couple of threads where I've seen them mentioned:
http://www.rallyamerica.com/hotrod_trucks/index.html They also sell used wheels, so they no doubt have the 6 lug centers: http://www.rallyamerica.com/usedwheels/chevy.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Wheel Vintiques have the pre 71 ralley wheel for our trucks in 6 lug in 15x12. They have the 5 small slots in them but otherwise are the same as plain steel wheels. You can order them in various back spacing from them as well.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
If you have access to a welder, possibly you could purchase a set of white spoke rims 10" wide and cut out their centers. Cut the rings off your stock 6 lug wheels and weld your centers onto the 10" rings. Mount them on your rear axel to true the centers so they turn without a wobble.
I cut the original 16" wheels in half added a piece of flatstock to make the wheels 9.5" wide, then reinstalled the original center for my 63 C10 I'm doing a set of 17"x 6.5" for my K10 project, converted from the 17.5"x5.25 original wheels.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
1961 crewcab
that ralleyamerica is a good place to go through, if you go to the h.a.m.b. at all, contact wheelkid over there, they should be able to make you a set.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks guys, this is exactly what I was looking for.
GGinferno, how wide are your wheels, and is the rearend shortened?
#9 | ||
Registered.........
![]() Quote:
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
