Old 04-15-2010, 06:56 PM   #1
70stroker
70stroker's Avatar
throttle rod to cable
I have a 70gmc that came out with a rod operated throttle. my bracket on the firewall that hold the pivot rod in cracked and i cant seem to find a replacement.
I noticed 71-71 had cable according to lmc. how hard or is it possible to convert a rod operated cab over to a cable operated?
Thanks in advance
70stroker is offline   Reply With Quote
Old 04-15-2010, 08:21 PM   #2
JimKshortstep4x4
Re: throttle rod to cable
In 71 they went to the cable and it involved modifying the firewall for the mounting bracket. You can massage your firewall or weld in a section of firewall from a 71-72.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-15-2010, 08:24 PM   #3
RaceAGMC
RaceAGMC's Avatar
If I'm not mistaken there is someone on here who makes a 71-72 pedal conversion for the 67-70 trucks that makes it a direct bolt on. I'm sure someone will chime in.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 04-15-2010, 09:51 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
I sure hope so. i would like to do this on mine.
68C15 is offline   Reply With Quote
Old 04-15-2010, 10:19 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=371099
http://67-72chevytrucks.com/vboard/s...00#post1383300
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
