The Black Pearl
front end specs ?
Hey could someone help me out. i'm buttoning up my front end on my 68 c20 what are the torque specs for tierods, balljoints, relayrod etc...? Is their a thread somewhere that has all of these specs?
Re: front end specs ?
I found this a long time ago but can't remember where. Someone else might have better info:
UPPER BALL JOINT NUT Upper ball joint nut torque specification is 50 lb-ft, tighten to align cotter pin if necessary but don't exceed 90 lb-ft. 1/2 ton trucks: 60 lb-ft (81 Nm) plus the additional torque to align the cotter pin. Do not exceed 90 lb-ft (122 Nm) and never back the nut off to align the pin. UPPER BALL JOINT NUT ATTACHMENT NUTS 45 lb-ft LOWER BALL JOINT NUT Lower ball joint nut torque specification is 90 lb-ft, tighten to align cotter pin if necessary but don't exceed 130 lb-ft. 1/2 ton trucks: Install the ball stud nut and tighten to 80-100 lb-ft (108-136 Nm) plus the additional torque to align the cotter pin. Do not exceed 130 lb-ft (176 Nm) and never back the nut off to align the pin. SPINDLE NUT 15 lb-ft then back the nut off to align the castle nut slots with the cotter pin hole. UPPER CONTROL ARM BOLTS Tighten the nuts to 80 lb-ft (108 Nm). 1/2 ton trucks: Tighten the nuts to (95 Nm). LOWER CONTROL ARM BOLTS 1/2 ton trucks: Tighten the nuts to 85 lb-ft. (115 Nm) |
![]() Join Date: Oct 2009
Thanks for the info!!! Getting mine together now.
Justin
Justin 71' C10 SWB 00' Dakota R/T 05' Z-71 Silverado 16' Z-71 Silverado Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=376904 |
