04-15-2010, 09:30 PM | #1 |
Grandpa in the rustmobile...
How to fix my split trailing arm...or should I replace?
Long story short, got in a wreck (t boned).
Broke my panhard/track arm bar, carrier bearing, and split my trailing arm. Can I fix my trailing arm or is it done? I just sandblasted/painted it/put new pushings in it..It looks like it was just rivited together..can I weld it back? Can I bolt it back? How should I go about fixing it? And it was a 'totaled' truck. So will I have to get it checked out before it goes back on the road? Thanks guys! Here is a pic I can get more if needed. Edit, in this picture, it doesnt look freshly painted, I guess it got roughened up slightly..lol the nuts on the U bolts just slid right on through...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 Last edited by oldblue1968chevy; 04-15-2010 at 09:31 PM. |
04-15-2010, 10:21 PM | #2 |
Re: How to fix my split trailing arm...or should I replace?
I would not risk it and replace both with new trailing arms like the ones from ECE is what I did with my truck.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 04-15-2010 at 10:27 PM. |
04-15-2010, 10:27 PM | #3 |
Has more rust than truck...
I would find good used and replace it. Something tells me even if you get it back together it will never be quite straight or the same.
04-15-2010, 10:29 PM | #4 |
..what about factory (JUNKYARD) trailing arms that arent rusted out? Im not building a show truck or anything. Im on a HS budget but dont wanna half butt stuff. Are Swb and lwb trailing arms the same? and ya think i could get my old bushings out of my arms and press em back in a diff. set?
Reason I ask on here because everyone around here is cheap and willing to...rig...something together, whether is safe or not...I hate to go to alot of trouble to replace if its safe and reasonable to patch my existing arm. Thanks keep it comming yikes ECE arms are nearly 500$ lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-15-2010, 10:35 PM | #5 |
should I replace both??
Man bigal your making me jealous...may call ECE about a drop kit while im there again..but will probably keep factory arms..
04-15-2010, 10:40 PM | #6 |
its all about the +6 inches
good used is fine, 3/4 ton would be better... SWB, LWB, fleet/step... all the same size.
04-15-2010, 10:44 PM | #7 |
#16876
I'd weld it up if its not bent.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
04-15-2010, 11:55 PM | #8 |
? 3/4 ton? They are all leaf springs I thought...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-16-2010, 12:09 AM | #9 |
TOTY 2006
3/4 can have trailing arms as well, Easy to identify as 3/4 arms have extra plate welded on bottom of arm.
04-16-2010, 02:18 AM | #10 |
I went with ECE and i have my stockers in the garage if you want to pay for SH. They are still intact just surface grime. I can take pics if you want.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
04-16-2010, 05:14 AM | #11 | |
Sorry, not trying to make you jealous. I just like to do things one time and well done. You could also get two used ones and reuse your new bushings. There are plenty of guys here that sell used parts. Whatever you do, do not rig it up. Good luck!!! If I still had mine I would just give them to you but I sold them for shipping cost almost a year ago.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
04-16-2010, 06:45 AM | #12 |
Watch out for your cornhole !
I'd clamp it tightly back together and stitch it up with the welder. It's just metal, not something exotic. Get it tightly back together, straight and give it hell.
04-16-2010, 07:32 AM | #13 |
LOL
No hard feelings Al! I understand, I like things the best too! I just dont wanna spend 500 on on a 2500 truck that you'll never see the arms, your trucks a beauty! Weld it or bolt it? Anyone? Where should I place the welds?
04-16-2010, 08:04 AM | #14 |
Junior Member
It really depends on a couple of things, is the arm straight and how fast and hard do you drive your truck.
The way I drive I would feel safe if the arm is straight to bolt the arm together in about 4 places and then weld it. Bolting it together would get the arm pulled together so the welding could be done right. I am an old guy and rarely ever drive my truck over 55 mph. At my age I have no need for speed in my old trucks. I do occasionally have the urge to light up the tires, though. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-16-2010, 09:03 AM | #15 |
Not sure how far you are from Western Kentucky but I could probably come up with a trailing arm but shipping it would be a b*!tch. If there was no serious metal damage I would have no issues welding the one you have however I would want to make sure it was not twisted.
1968 C10 SWB "Project Shop Truck" 1964 Impala 2DR Hydraulics 1933 Ford 2DR Sedan 1965 AC Cobra (Long Term Project) 1998 Viper GTS-R 1962 Chevy RampTruck (SOLD) |
04-16-2010, 09:18 AM | #16 |
#16876
My 63 c20 has trailing arms. Glad it does. Made it easier to lower. I used 1/2 ton coils.
04-16-2010, 12:02 PM | #17 |
Truck Builder, October 2003 has an article on reinforcing trailing arms- Strong Arm Tactics Installing Trailing Arm Reinforcement Kits
It's available on-line on ECE's website. The reason for pointing this out is simple...this article discisses how to reinforce a set of arms but you could also repair yours in this fashion if you're uncomfortable with just replacing the rivets with bolts. TX Firefighter is right, if the arms aren't bent just run a bead re-attaching the two halves...for a fix on a budget that will work nicely, just be sure to clamp the two halves together with the U bolts in their holes so you're sure everything will line up correctly while you tack weld them together. If you aren't comfortable with your welding skills get a quote from a welding shop and compare it to a price for replacements...if you're humble a welder may help you or just check on the shipping costs for Ripdog's arms. Last edited by Fitz; 04-16-2010 at 12:03 PM. |
04-16-2010, 04:57 PM | #18 |
Six in a row makes it go...
I posted some pictures of what I did to my 3/4-ton arms in this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=397793
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
04-16-2010, 06:22 PM | #19 |
well i got it off and it looks striaght i'll get some pics...and where the panhard bar bolts to the rear axle, the stud comming off looks a little bent..i'll post a pic it may suppost to be like that idk..
thanks
04-16-2010, 08:27 PM | #20 |
Car Knocker
Mine Split when I was knocking the u bolt out for rear end swap. I just finished drilling out the rest of the spot welds and cleaned up with a grinder. Primed the inside and put pieces back together with bolts and clamps and welded them up. IMO will be stronger than the original 1/2 ton arms that I had.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
04-16-2010, 10:39 PM | #21 |
if you need sombody to weld them for you i can do it for you. just bring them to the boro.
04-16-2010, 11:35 PM | #22 | |
i am putting air ride on my 67 and am switching to a 4 link...
04-16-2010, 11:58 PM | #23 |
Well, im still undecided. My neighbor is a welder by trade (used to do nuclear powerplants in Fl) and welds at a local air force base...i'll see if he cant do it soon otherwise i'll get a factory arm or find someone else that can weld.
thanks crusher! Id take ya up on it but my blue truck is my DD and I dont have another vehicle, id love to check out your truck(s) sometime! I got it all tore down today. Im getting new u bolts for drop blocks, I got my panhard bar off the axle side, but cant drive the bolt out on the frame side? Any tips? I think my stud comming off the axle got a little bent, MAYBE i'll post pics tomorow for you guys to see. And dad bought me the wrong carrier bearing today, but he picked me up a tranny seal. got it installed tonite, things to do: ?trailing arm? need a panhard/track bar maybe rear axle order my new u bolts get my bedside off find/install new bedside, Tim is helping me on this one, how much yall think it'll cost to ship a bedside from KS to TN? thanks!
04-17-2010, 12:08 AM | #24 |
Look on eBay for used stock car trailing arms. Under 100$ a pair I believe. and they're a direct fit. A member on here went with that option and posted about it.
'72 cheyenne super step, '05 long bed gmc |
04-17-2010, 12:12 AM | #25 |
Well, the arms I havent arent bent, just split in 2 parts, I just sandblasted and painted them and installed new bushings I hate to ditch them but Dont wanna rig it together....
