NP 205 Mounts
I am going to replace my rockwell transfer case for a divorced NP205, I want twin stick control + it's a better case, it's going into a 62 chevy, do any of you have pictures of how you mounted that case in an earlier truck. Any advice would be appreciated, thanks, Larry
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: NP 205 Mounts
You can make your own mounts out of some iron. That really isn't very hard, just take some measurements and center the driveshafts up. I really recommend that you mount the case dead center of both axles as you could always use the front if something happens to the rear to get you home. That's what we did on the 96'. If I remember, I will take some pics of the mounts off it tomorrow. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
Re: NP 205 Mounts
Thanks, I'm a visual learner I would appreciate the pictures, Larry
Re: NP 205 Mounts
I had a local metal shop make me one. Not sure if I have pics or not in my sig. But something else to consider, older Dodges that had this t-case have the same frame width as GMs, might be able to use that over a scratch built.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
Re: NP 205 Mounts
Right here....http://rides.webshots.com/photo/2569...dK?vhost=rides
Re: NP 205 Mounts
Thanks for the pictures, and the infor on the dodge, I'll look into that as well, the mount sure looks like something I could do, Larry
