Old 04-16-2010, 09:21 AM   #1
TomJohnston
TomJohnston's Avatar
best 2" rear or 1"-3" drop
I'm looking at doing a drop on my 70 c10 - either a 2" rear to level it or a 1"-3". Are new springs enough or is there a better way to do it. How bout shocks? do I need to use drop shocks with that setup?
Dad's 1970 Chevy C10 Custom
350, auto, armstrong power windows and doorlocks
"My carbon footprint is bigger than yours"
TomJohnston is offline   Reply With Quote
Old 04-16-2010, 12:50 PM   #2
threeonthetree
threeonthetree's Avatar
Re: best 2" rear or 1"-3" drop
i wouldn't think that you would need drop shocks.
id say a 2"
you could take a tape measure and measure the front on level ground. and then the back, and find out the difference that would give you a ball park.
someone else should chime in. or try the search function.
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 04-16-2010, 12:54 PM   #3
stevencvn72
Kill Bill...et
stevencvn72's Avatar
You could just put in a two inch block. Pretty cheap and it'll keep the origional geometry.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 04-16-2010, 01:43 PM   #4
threeonthetree
that's a great idea!!
i shoulda thought of that. ha
1969 c10 AKA SIN
1985 SSWB TRAZER
Old 04-16-2010, 04:31 PM   #5
TomJohnston
I thought you needed to have leaf springs to use a drop block.
Old 04-16-2010, 04:37 PM   #6
stevencvn72
Kill Bill...et
Nah...Same concept. Longer u bolts and a block. Goes between axel and trailing arm mounting point. Take a look at your truck and it'll make sense.
Throw up a search on the forum. There's a thread someone did building his own blocks with the install. Easy money. Or CPP (and a few other places too I'm sure) sells them for some $.
-Steve
I Grease
'67 Chev stepper
