04-16-2010, 06:57 PM | #1 |
Installing Front Lower Bump Stops
Has anyone installed new front lower bump stops? What is the secret? Thanks
04-16-2010, 07:02 PM | #2 |
member #16
Re: Installing Front Lower Bump Stops
Determination.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
04-16-2010, 07:59 PM | #3 |
heat em and lube em
04-16-2010, 08:00 PM | #4 |
I also used a small flat screw driver to pry the one side down once I had one side in.
04-16-2010, 08:27 PM | #5 |
try and outthink them
04-16-2010, 08:51 PM | #6 |
Watch out for your cornhole !
10 seconds in the microwave will soften them enough to make the job easier.
04-16-2010, 08:59 PM | #7 |
frankdatank01 is right. I replaced mine a few months ago and had to take them off and re-install just the other night as I wanted to trim them down a bit. Lubing them up both times worked for me. WD40 works good, does not leave a mess and will eventually wear away. Spray some on the bump-stop tab and try to press it in the slot on the a-arm. If you can get just part of the tab inserted (a small flat-head screw driver helps with that) then turn the bump stop clockwise and then counterclockwise (sorta of twisting it in but use a bit of finesse here so as not to rip the tab off) will allow for the rest of that tab to fall into place. Hope this helps. It also helps if you can get your Truck off the ground a bit or if you have access to a lift. Hope this helps.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
04-16-2010, 09:31 PM | #8 |
Yep Lube screwdriver and some cussin
