I have a stupid question....
Is there a trick to installing front control arm bump stops? I bought some Energy Suspension pull-thru's (3-9101G) and (3-9103G) to replace the torn and cracked factory control arm bump stops and for the life of me I can't get them in. It's almost like the pull-thru tab is too short. Is there a certain way to pull them through? I noticed on Silver's build thread that the tabs on his bump stops are a little longer. (By the way, that's my dream build right there.)
Anyway, what bump stops are you all using for your front control arms? |
Badass
Re: I have a stupid question....
heat the up alittle to make them softer and try pulling it threw
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
I tried that and also popped my lips twice, tilted my head to the right, closed one eye, and stuck my tongue out a bit and that STILL didn't work.
I just thought of something, though. If I'm going to be dropping it 5 (or 6)/7, do I even need the bump stops? I've read in different posts that people cut off the entire bump stop perch. Are either the upper or lower bump stops used with a 5 (or 6)/7 drop? |
I dont know if its right or not but im not using any bumpstops cause they were actually in the way.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
Badass
i lowerd mine 4/5 and still have the bumpstops
and you gotta hop on one foot when you have your eyes closed and your tongue out. hahaha
