3/4 to 1/2 ton swap
Hi guys. I have started working on a 71 3/4 ton, and a freind of mine has a 72 1/2 ton that he is going to part out. I would like to swap over the 5 lug stuff so I have more options for wheels. Bolth trucks are coil rears. Does anyone know what all I have to take off the half ton as far as the front suspension goes? This is my first post, but I can't even imagine doing the work that I have done on this truck so far without the info that I have gotten from this site! Thanks for the help!
Re: 3/4 to 1/2 ton swap
I did this on my suburban. You will need 1/2 ton ball joints and tie rod ends. (I would buy new ones instead of re-use the 30 year old ones) Swap the spindles, rotors, and wheel bearings. Calipers are the same. For the rear it's a straight axle swap, unbolt and roll out the rear end and roll in the new one. You may need a custom U-joint. I did. The 3/4 ton driveshaft has larger bearing caps than the 1/2 ton so you will need a 3/4 ton u-joint on the shaft side and a 1/2 ton joint on the axle side. Napa had this in stock.
So I will put 1/2 ton ball joints in the 3/4 ton A arms?
I would just swap out the entire front suspension - especially if the motor is out of your truck - it's only 14 frame bolts, the steering box, shocks & idler arm. If both motors are out & you have an impact gun you can do the whole swap in just a couple of hours -then everything on your truck will be half ton. If the motors are in, might be quicker to do it as the previous poster said.
RIP Mr Ron
![]() Join Date: Dec 2005
We did this swap last Sat. on a 72 Blazer 2wd. 2 guys (Woody and Luv2xlr8) swapped the front alone in about 2 hrs. See link for pics. You have to scroll down to pics.
http://67-72chevytrucks.com/vboard/s...=369482&page=3 Rear was less.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket Last edited by Ron 586; 04-17-2010 at 01:59 AM. |
You will need the 1/2 ton lower control arms too. The 3/4 ton ball joints are larger diameter seating area. So the 1/2 ton ball joints won't mount into the 3/4 ton lower control arms.
#7 | |
'66 c10ish straight 292 power! |
Junior Member
When we did mine I got the conversion joint from Fisher Auto Parts (Federated). I can not remember if it was a 348 or a 358 though.
We went from a 3/4 ton 4 speed drive shaft to a half ton rear-end. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
