Old 04-16-2010, 11:42 PM   #1
Critter
Future TOTM Winner
Critter's Avatar
Big Block Brackets and A/C?
Does anyone have a nice pic of what the stock A/C compressor setup should look like on my 78 454? I'm familiar with small blocks but this is my first big boy and I'm feeling a little lost for knowledge.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-17-2010, 07:47 PM   #2
Critter
Future TOTM Winner
Critter's Avatar
Re: Big Block Brackets and A/C?
Nobody has a Big Block with A/C? I searched as well but didn't turn anything up.
Old 04-17-2010, 07:55 PM   #3
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
just roll down the windows and pin it !!
that's my ac setup on my big block, which happens to also be a 78 454
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 04-17-2010, 07:57 PM   #4
Critter
Future TOTM Winner
Critter's Avatar
Yeah, but that's the "heater" option here in Texas.
Old 04-17-2010, 08:01 PM   #5
Burlinator
Burlinator's Avatar
spend two grand and get this setup
http://static.summitracing.com/globa...ch-20360_w.jpg
Old 04-17-2010, 08:50 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
riiiight...the truck is worth about $500
Old 04-17-2010, 09:10 PM   #7
USSkoval
I also would like to see a pic, I'm guessing my '79 should be the same.
USSkoval is offline   Reply With Quote
Old 04-18-2010, 11:00 AM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
if you have v-belts you could start over with a set of serpentine belt brackets off of a 88-92 sbc camaro/trans am.. requires a little bit of modding, some 3/8 aluminum plate and your set. I did that on my 87 and used f-body a/c hoses, everything for the a/c was factory 87.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-18-2010, 11:07 AM   #9
USSkoval
^Caprice brackets can also be used, they are the same.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
Old 04-18-2010, 11:47 AM   #10
Critter
Future TOTM Winner
Critter's Avatar
Thanks guys, I don't think I am wanting to get that involved with it at the moment. The truck is (at the moment) just an old beater but I plan to drive it quite a bit for work purposes. I might just go get a v-belt Sanden compressor and make my own brackets. Here are a couple pics of the brackets that are currently there. I know I am missing a couple parts, but I haven't figured out exactly what...yet.
Old 04-18-2010, 04:22 PM   #11
new2trucks
This is of my 89 crew cab dually.
new2trucks is offline   Reply With Quote
Old 04-18-2010, 09:21 PM   #12
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Hopefully, this will help you out a bit.
It's from a '76 3/4ton where I pulled the motor out and re-worked it for my '87. I used the big pictures so you could blow them up and get good detail.
Good Luck.
Kenny
87Lowrider is offline   Reply With Quote
Old 04-18-2010, 10:11 PM   #13
Critter
Future TOTM Winner
Critter's Avatar
Thanks Lowrider, that's exactly what I needed!
Old 04-18-2010, 10:32 PM   #14
87Lowrider
87Lowrider's Avatar
