04-17-2010, 12:00 AM | #1 |
steering linkage ?
i did a crossmember swap and now im putting in the steering linkage and it seems that there is some interferiance with with my idler arm and sway bar bracket. does it need to be modified or did i do something wrong
any one got pics of what it should look like thanks. Last edited by cb1965; 04-17-2010 at 12:03 AM. |
04-17-2010, 12:41 AM | #2 |
60-66 Nut
Re: steering linkage ?
Which idler arm are you using?
04-17-2010, 01:49 AM | #3 |
im using the donor. i just mocked it up to the frame and it hits the sway bar bracket
04-17-2010, 11:48 PM | #4 |
60-66 Nut
I don't have a pic to post right now, but something isn't right. There is no need to modify the later model idler arm.
04-18-2010, 03:52 PM | #5 |
Registered.........
Here's a pic of later model (73-87) steering linkage on a 64-66 truck.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
04-18-2010, 04:15 PM | #6 |
thanks wild one.
do you have measurements on where the holes should be drilled or just eyeballin it. |
