04-17-2010, 10:28 AM | #1 |
Radiator Options
Can anybody tell me what options I have for a replacement radiator for my 66. I'm pretty sure this has been talked about so if you know what thread it is a link would be cool. the search engine is not being my friend today and I would like to spend more time working on the truck and not on the internet.
the original radiator has a leak and not sure if it can be fixed. I'm going to take it to a radiator shop today. But just in case it's too far gone are there other vehicles that have similar radiators that would fit? any help will be great. thanks Ed |
04-17-2010, 11:26 AM | #2 |
Senior Enthusiast
Re: Radiator Options
As long as the tanks are usable, any competent radiator shop can rebuild your original even if it requires a new core. There are also replacement radiators available from any of the classic truck suppliers, or there are universal radiators available from Summit Racing and Jegs. All you need is something that will fit in the space available, and has the right size radiator hose outlets on the correct side of the truck. Griffin Radiator (and probably others) will also custom build one for your application, but cost becomes a major consideration when dealing with any of the new radiators. Before spending money on a new one do some research so you make an informed decision on whether aluminum or copper/brass is a better selection for your situation and budget.
I'm running a 1968 Impala air conditioning radiator in mine, but the chance of finding a used one in a wrecking yard isn't much better than finding an original truck model in good serviceable condition. And here are some previous threads on radiator options: http://67-72chevytrucks.com/vboard/s...light=radiator http://67-72chevytrucks.com/vboard/s...light=radiator http://67-72chevytrucks.com/vboard/s...light=radiator http://67-72chevytrucks.com/vboard/s...light=radiator http://67-72chevytrucks.com/vboard/s...light=radiator
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 04-17-2010 at 11:31 AM. |
04-18-2010, 11:42 AM | #3 | |
http://www.rockauto.com/catalog/raframecatalog.php Ed |
04-18-2010, 12:26 PM | #4 |
those radiators fit but not perfect. I have one also and it really dose not center up with the support so if you are running a shroud it might be difficult.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-18-2010, 12:30 PM | #5 |
http://shop.ebay.com/i.html?_nkw=196...sacat=0&bkBtn= Here are some aluminum radiators on Evil Bay.
04-18-2010, 03:43 PM | #6 |
Registered.........
You might want to try theses guys: https://www.1800radiator.com/ I purchased mine through them,delivered to my door for right around $200.00 for a three core radiator. They come with a lifetime warranty (which I have to admit I've already had to use once) and they do stand behind their product. It was a very close fit, the only difference was the lower radiator brackets - I had to relocate them inwards IIRC.
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life |
04-18-2010, 10:09 PM | #7 |
I used a replacement that I bought at O'Reilly's, I will try to post the PN tomorrow. I was able to use 67-72 upper an lower brackets to hold it in place. The attached pics don't show th lower mounting, I will try to post those later.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
04-18-2010, 10:10 PM | #8 |
I will try this again....
04-18-2010, 10:13 PM | #9 |
I'm beginning to feel attachment challenged
04-18-2010, 10:53 PM | #10 |
Hey Ed,
I used this one from evilbay. http://cgi.ebay.com/ebaymotors/Alumi...item2a022af0e7 It fit the stock mounts with a little trimming of the lower brackets and a little grinding on the rubber isolators. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
04-18-2010, 11:25 PM | #11 |
__________________ 65Gregg Dude what radiator did you use,pn please if you would.Did you have to modify your inner fenders? Mods remove this one entry as it is a duplicate,I messed up.Thanks!! OH!! my apologies!! Last edited by low79fx; 04-19-2010 at 07:57 AM. Reason: Duplicate entry,mistake. |
04-19-2010, 07:53 AM | #12 | |
Dude what radiator did you use,PN please if you would.Did you have to modify your inner fenders? |
04-19-2010, 09:31 AM | #13 |
Senior Enthusiast
Do you rememer the original application for your upper radiator hose? The molded hose looks like a perfect fit.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-19-2010, 12:10 PM | #14 |
I will get the part # tonight for the radiator and the upper/lower hoses, if it stops raining I will also have a picture of the lower mount to give you some ideas.
04-19-2010, 09:14 PM | #15 |
The part # for the upper hose is Gates#20694, it was for a 69-72 V8 application. I will attach the label off of the radiator box, I kept it with all of my receipts. I couldn't get any pictures of my lower mounting arrangement, all it amounts to is a long carriage type bolt through the lower mount from a 67-72 truck. It is spaced up from the core support to the height you want with a nut on the top and bottom of the core support. The low profile head allows it to fit under the rubber cushion in the mount.
04-19-2010, 09:15 PM | #16 |
Senior Enthusiast
Thanks so much for the hose number!
04-19-2010, 09:23 PM | #17 |
The only modification needed was the removal of the original radiator mounting brackets them mock up the mounting position drill the holes and done. When I got the radiator the overflow was turned in the direction of the battery which created interference with the hose, I had the locate shop turn the neck and ran the hose back across the top of the radiator and used the wiper tank for my over flow.
12-13-2010, 01:40 AM | #18 | |
But Found Her 25yrs Later!
Do you have a name or part number? Thanks
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-13-2010, 02:41 AM | #19 |
I'm leaning toward this one:
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT Anybody see a problem with this choice?
12-13-2010, 09:55 PM | #20 |
Get the 3 Row. That is the one I have. It cools great!
TR
