04-17-2010, 12:41 PM | #1 |
Roadtrip!
Power-lok help
Going to look at a 72 parts truck and it was originally a 3/4 ton big block truck. I do not know what rear end is in it, but it has power-lok listed on the glove box. What is the easiest way to verify it is a posi, and how much work is it to pull the posi unit only? I don't want to pull the whole rear if i don't have to. Thanks for any tips, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-17-2010, 01:50 PM | #2 |
Re: Power-lok help
if posi why not take the whole rear?? that posi section wont fit in a 1/2 ton 12bolt rear
04-17-2010, 02:21 PM | #3 | |
Roadtrip!
Re: Power-lok help
It is alot easier to store the center section than to try and move a whole rear end around.
04-17-2010, 03:36 PM | #4 |
Active Member
Re: Power-lok help
I dont know if a 3/4 ton Power Lock works the same as 1/2 ton Posi
But if it does; lift the rear off of the ground " both wheels " By hand roll one wheel, if the other wheel rolls in the same direction, its a Posi, a 1 leg unit rolls in opposite directions. I'm with cdowns, take the whole unit. |
04-17-2010, 06:59 PM | #5 |
Roadtrip!
Re: Power-lok help
If i take this apart, what am i looking for visually?
04-17-2010, 07:06 PM | #6 |
Re: Power-lok help
That`s a Dana60 3.54 rear.I`d take the whole thing.
04-17-2010, 11:00 PM | #7 |
Re: Power-lok help
Yep, Power-lock is a Dana and No-spin is an Eaton (ho52)
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-17-2010, 11:35 PM | #8 |
Member #1049
Re: Power-lok help
I agree with all above.. its a Dana 60 3:54 ratio.. (assuming its the one that came with it from the factory)..
I usually pull the fill plug on the rear cover and stick a finger in.. if finger goes in more than an inch its a non-posi... or jack it up and spin a wheel.. if the opposite side spins the same direction its a good bet it's posi.. Visually....... Here is a pic.. Last edited by Livrat; 04-17-2010 at 11:35 PM. |
04-18-2010, 05:07 PM | #9 |
Roadtrip!
Re: Power-lok help
Thanks for the help, looks to be a dana 60. Took a chance and bought the whole truck. Couldn't verify the posi part, but had enough other parts on it yet...
04-18-2010, 05:31 PM | #10 |
Re: Power-lok help
Joe and Tim, I was reading your comments on the 3/4t rear end. Which is more desirable the Dana or Eaton? We have both and wanted to put one of them in our 72 longhorn. Anyones else's opinion is welcome.
Thanks Paul and Jason
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
04-18-2010, 06:42 PM | #11 |
Roadtrip!
Re: Power-lok help
I believe the dana 60 is easier/less expensive to buy parts for. I think the eaton may be stronger. I am sure you will get more input on this.
04-19-2010, 10:44 PM | #12 |
Roadtrip!
Re: Power-lok help
Ok, i took the advice givin and bought the whole rear end..... and the rest of the truck. 1972 3/4 ton gmc sierra. Looks like the original rear is still in it. Still has one tag that reads 461
3:54 and the remnants of another tag that probably read "use posi lube only" or what ever a dana tag would read. I pulled the drain plug and also saw these numbers inside 72 A 22934X. Not sure what those mean. Thanks for the help, Eric
04-20-2010, 12:09 PM | #13 |
Active Member
Re: Power-lok help
Sounds like it still has the original Power-Lock.
I think that ( 72 A ) is for, Jan 1972 |
