04-17-2010, 02:13 PM | #1 |
smoothing interior parts
so, im in the process of smoothing the "grain" from interior pieces, im using a high build primer, and light glaze in some areas onm the metal pieces, wondering what you guys have used on the plastic pieces?
2006 GMC Sierra CCSB, 6.0 swap 2000 Chevy C3500 Crew Cab shortbed dually 1999 Chevy c2500 Crew Cab shortbed 1982 El Camino 350/350 1979 K5 2wd blazer bagged/bodied 1986 Monte Carlo SS 1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4 1955 Chevy Bel Air 2014 Chevy Silverado ccsb |
04-17-2010, 03:39 PM | #2 |
Re: smoothing interior parts
Firberglass resin, let it set up so its a little thick then paint it on let it dry then sand it down. I've heard good things about slick sand, haven't used it though.
Project "Abby" 84 swb 6.0 swap and rebuild. http://67-72chevytrucks.com/vboard/s...d.php?t=395121 |
04-17-2010, 05:49 PM | #3 |
i have also heard of sanding all the texture off then doing a high build primer that way you know they will never crack!
