1964 Chevy C20 Parking Brake
I am new to the forum. This looks like a great site to talk to fellow Chevy Truck fans. I have a recently purchased 1964 Chevy C20 Longebed Stepside Truck. I accidently took off driving it without fully releasing the parking brake lever. It's teh Heavy Duty version with the leaver in the floor, not on the dash. A few miles down the road I got a burning smell and a cloud of smoke form under the truck. I quickly realized what was wrong and released the lever. Ever since that, my park brake is not working and I can smell a sort of burnt smell when I drive the truck. I have also noticed that it is almost like the brake is dragging or partially engaged. I checked under teh truck and cannot see anything visually wrong at the back of the transmission, where the park brake"drum" is located. Anybody got any ideas on what's going on here?
1961 crewcab
Re: 1964 Chevy C20 Parking Brake
probably the pads on the drum are worn out nowand that is why the brake does not hold.
I would probably jack it up and put in nuetral, and get under there and turn the driveshaft by hand, to see if the whole drum is dragging.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
^ What he said and there is an adjustment rod that's threaded and may need tightened to actually grab. I had to do this to mine, I had to pull the parking brake so hard it would smash into the floor towards the seat. Now it only needs pulled halfway to hold the truck on a flat surface, then pulled all the way if its on a slight hill.
