Old 04-17-2010, 05:03 PM   #1
truckdrivinsob
Gear Jammer
truckdrivinsob's Avatar
Opinions needed???
Hey guys been a while. Been driving the pick up everyday and just aren't happy with the v8. Mainly because i cant keep my foot out of it and mpg's are not that great. I have a 292 out of a 66 Chevy c20 government truck. It needs a little freshening up but no big. I just want a nice cruiser basically and since my son is gonna get it, it doesn't need to be a race car.
My mind is made up just want to know what you 292 guys think? It will have the th400 from the v8 and 3.05 gears in the rear end. Any thoughts?? Will it run ok with that drive train?
Thanks in advance!!
SOB
truckdrivinsob is offline   Reply With Quote
Old 04-17-2010, 05:19 PM   #2
Shaky
Six in a row makes it go...
Shaky's Avatar
Re: Opinions needed???
292/TH400/3.07 will cruise nice. Just be warned - 292s do not get good mileage. What they do is give lots of torque down low.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 04-17-2010, 05:25 PM   #3
truckdrivinsob
Gear Jammer
At least little better than 12ish ???
Old 04-17-2010, 05:43 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Depending on what V8 you have, and if it's in decent condition, you should be able to do a lot better than 12ish with some modest upgrades. Perhaps a new carb, HEI, tuning on the carb, new plugs, good wires, etc. Of course the end result also depends on the rear axle ratio and as you noted - driver restraint!
Years ago I got better mileage after a 283 swap than I did with the original 235, because I didn't need to push it so hard to perform. With the 6 I drove with my foot on the floor all the time to get similar performance.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-17-2010, 05:45 PM   #5
cayoterun
Junior Member
cayoterun's Avatar
We used alot of 292s on small irrigation wells. They'll run forever and ya' can't break 'em.
Don't know anything about mileage as they run on natural gas. Just know they're are tough and lots of torque. For a smaller motor, I don't think there's a better engine.
Cayoterun
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 04-17-2010, 06:24 PM   #6
truckdrivinsob
Gear Jammer
OK well i am just over the v8 and i got the 292 siting there. i understand the work harder principle so.i guess its a give it a try and see what happens.
Old 04-17-2010, 08:37 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
The flow through heads of a small block offer better volumetric efficiency versus the single sided I6 head. Build a flow though head for your 292 and you might improve mileage over the V8. But the cost to do that would defeat the econimics of the swap.
Frizzle Fry is offline   Reply With Quote
Old 04-17-2010, 09:06 PM   #8
truckdrivinsob
Gear Jammer
Well damn!! Maybe new carb and manifold swap? I have an old offenhauser(?) dual plane on it and an 585cfm holley. It has pertronix in the dizzy and a high volt coil. They are the big valve heads so idk???????
Old 04-17-2010, 09:43 PM   #9
K-TEN
The Turbo 400 will eat up quite a bit of power to just get it moving. A Turbo 350 or a standard would help in the mileage department. And if your going to swap transmissions, then just get an early 700r or 200r. You could probably trade even with someone looking for the 400. The overdrive of a 200r will definitely help in the mileage department, as well as the reduced power necessary to get that trans moving.
A 292 has 7 main bearings and is a tough motor. There is a ton of performance work that has been done by Leo Santucci. Look for his books. With some careful parts selection and some fine tuning, you should do quite well with that 292.
Amazon.com: Chevrolet Inline Six-Cylinder Power... Amazon.com: Chevrolet Inline Six-Cylinder Power...
K-TEN is offline   Reply With Quote
Old 04-17-2010, 09:51 PM   #10
truckdrivinsob
Gear Jammer
Really the th400 would effect that? Hum i think i am leaning towards carb and manifold swap. I just dont know any more????????
Old 04-17-2010, 10:10 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
the th400 is a tough tranny but will drag the mileage down. i second the 700r4 if you have to do it. the od will be nice for cruising and mpg. I would tune the v8 up, and run an overdrive trans. better mpg and you don't have to sacrifice having the 8
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-17-2010, 10:14 PM   #12
truckdrivinsob
Gear Jammer
Ok sounds like the way to go. The motor has just been gone through so i am not worried about that. Just got off the phone with a friend and he says it sounds like electronics going bad maybe pertronix is messin up? I am on the look out for a 200r4 but i was told the gears would need to be changed so maybe just do a th350??
Old 04-18-2010, 07:07 AM   #13
Shaky
Shaky's Avatar
Unless your V8 is crazy, it'll be about comparable. I'm keeping the 292 in my '67 because it's original and I have a lot of parts for it.
The 250 is a different animal and you can squeak some decent mileage out of them.
Old 04-18-2010, 11:12 AM   #14
burbguy
burbguy's Avatar
I'm not a gear guy, but running the 700r with a set of 3:07's out back sounds like it's going to be gear'd too fast. the t350 idea might be the ticket, as you don't need an overdrive with those gears (depending upon your tire size)...? just my 2 cents...
burbguy is offline   Reply With Quote
Old 04-18-2010, 01:55 PM   #15
truckdrivinsob
Gear Jammer
ok sounds good, tires are 225/75r15. I think the electronics are going hay wire with further research in to my problems. i dont want to go hei i dont like the looks of them but may haft to! i have heard the same thing on the 700r4 if i would have left the 4.11's it would have been perfect.
Old 04-18-2010, 02:06 PM   #16
Rogue
Airport Bum
No way I do a build these days without a OD.
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 04-18-2010, 04:10 PM   #17
EVBuilder
EVBuilder's Avatar
For those that don't like the look of HEI here is an alternative. Also I agree the TH400 is a power hog. I have heard they eat more power than any other automatic. TH 350 is way better for that.
http://www.summitracing.com/parts/MSD-8474/ [/URL]
EVBuilder is offline   Reply With Quote
Old 04-18-2010, 05:42 PM   #18
truckdrivinsob
Gear Jammer
Ouch!!! I can get a new HEI at super shops for 69 so i might just bite the bullet and do it. Hey i guess i dont haft to open my hood!!
Old 04-18-2010, 07:48 PM   #19
astrochimp
For MPG you need to pick part to make power in the RPM range you drive in. Most aftermarket parts make more power at higher RPM but lose power where most of us drive..
An early 70's cast intake and q-jet are very hard to beat.
Finally did a base MPG on mine the last two weekends, right at 10. Actually it was even worse when I got the truck.
astrochimp is offline   Reply With Quote
Old 04-19-2010, 04:42 PM   #20
Frizzle Fry
A good dual plane aluminum manifold will be hard to beat for mileage/performance in a street-driven truck. Edelbrock Performer or equivalent would be my choice for your application.
Old 04-19-2010, 05:27 PM   #21
Russ65C10
Russ65C10's Avatar
I stear away from a 200R4 behind a 292, too much torque. With the 3.08 gearing I'd go with TH350 or 700R4 although with the 700R4 I'd seriously think about about going with a lower geared rear end.
Russ65C10 is offline   Reply With Quote
Old 04-20-2010, 05:15 PM   #22
truckdrivinsob
Gear Jammer
Russ i would not not be switching motors if i go 200 or 700 r4. I am just trying to make a choice between v8 and od or 292 th350
Old 04-20-2010, 05:32 PM   #23
Russ65C10
Russ65C10's Avatar
Ok, I went back and read your original post ;-)
Go with the 700R4, you get better mpg than with the 292 they're gas hogs. But don't expect to way better mileage. Here my experience. Keep in mind I have always like to "put my foot in it".
66 Short Stepside 250 inline 6, 3 speed, 3.73 rear end. 12 -14 mpg
65 Short Stepside 283 V8, 3.73 rear end 1st with a powerglide later with TH350 10 -12 mpg
65 upgraded to 700R4 12 - 13 mpg not much of an improvement.
What will get with OD is a truck that will cruse down the freeway at something like 2000 rpms, which makes for a much nicer (quiter) ride.
Old 04-20-2010, 05:37 PM   #24
Russ65C10
Russ65C10's Avatar
BTW - unless you're willing to spend a chuck of change and know a good tranny builder that knows their stuff on the 200R4 I wouldn't put it behind anything other than 250 or smaller inline 6. I tried the 200R4 route (it was a direct bolt in replacement for my powerglide) before I went with 700R4, the 200R4 in stock form is just not up to snuff behind a non-smogged small block. My basicly stock (headers & edelbrock performer intake/carb) 283 took no time at all to eat a 200R4.
Old 04-20-2010, 06:10 PM   #25
truckdrivinsob
Gear Jammer
Thanks for the info russ! I have heard the same thing about 200s i got a buddy giving me a 700 so i will go that route.
