Old 04-17-2010, 08:39 PM   #1
long69
help id power steering box fittings
need a little help in identifying which/what fitting this box uses. i bought this off ebay long time ago. after i got the pressure hose for what i thought it needed, i discovered that the inverted flare inserts were missing? but maybe not. might be a later model o ring type? the hose fittings i bought (69 ) do screw in and seem to be standard thread. it is a quick ratio unit. i thought i was getting a direct bolt in, oh well. all is not lost as i have found adapter fitting that may fit but i don't want to spent even chump change on a chance, i must know for sure. i used to have money but times are now rough.
ps: i got this box for a song and i'm not too bummed if it turns out to be a waste.
long69 is offline   Reply With Quote
Old 04-17-2010, 09:00 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: help id power steering box fittings
Looks like the later model metric fittings to me. I'm no expert though. If it is a metric box You could either get adapters from NAPA or get later model hoses. When I researched this before not everyone has success with the adapters. If you do the hoses you need the metric fitting on the back of the pump too.
OhOneWS6 is offline   Reply With Quote
Old 04-18-2010, 07:26 PM   #3
long69
thanks for the reply. i guess i might take a shot on a flare adapter insert like this
http://www.speedwaymotors.com/O-Ring...ter,24682.html
Old 04-18-2010, 08:10 PM   #4
hchad18
hchad18's Avatar
The adapters worked for me. And the threads are so close that the old hoses still work.
hchad18 is offline   Reply With Quote
Old 04-21-2010, 04:15 PM   #5
long69
follow up info
it seems there are o-ring fittings (threads) in both std and metric. the switch being made sometime in the mid 80's . disclaimer: this is what they told me.
there also MIGHT be a difference in the inserts themselves also- metric or standard.
i bought some inserts from:
lee manufacturing in sun valley ca. you can google it if necessary. they don't seem to have online ordering but you can call to order. they don't mind, i did ask. i picked mine up. cheaper than the other link.
Old 04-21-2010, 07:22 PM   #6
OhOneWS6
OhOneWS6's Avatar
Post up how it works out when you get done if you don't mind.
Old 04-21-2010, 07:29 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
This is one reason that I have Red Head steering gears build our quick ratio gears. We us the original housings and input shafts so they are direct bolt in, no adapters or modifications needed. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
