Old 04-18-2010, 10:23 AM   #1
1970CustomC10350
Thinking about buying a K20
HI everyone! We are going to look at a 69 K20 today. Is there anything we should watch out for? It is more or less a parts truck judging by the pictures. We have a decent 2 wheel drive 71 C20 and I'm thinking we will probably mold the two together and have a fairly nice 4x4. Is there any differences in cab to frame mounts and stuff like that, that would become an issue? Also, anybody that has a K20 I would love to hear about your truck. Like how does it handle, how does it 4 wheel ect. I have no idea what kind of options came on the K20's so I'm pretty naive about them. For instance did they make any full time K20's or where they all part time? Any info would be great guys.
1970CustomC10350 is offline   Reply With Quote
Old 04-18-2010, 10:31 AM   #2
jeremy zander
jeremy zander's Avatar
Re: Thinking about buying a K20
Welcome,I am a k20 fan.They did not make a full time 4wd.They usually rust out before they stop driving(rockers,cab corners).the drivetrain is all workable and plenty of available parts to increase the fun..350 motor 350 tranny np205 tcase.all very good stuff...
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 04-18-2010, 10:53 AM   #3
Mike C
Mike C's Avatar
Just plan on ditching the drum brake front axle sooner rather than later, rest of the driveline should be fine. Could be either an Eaton HO52 rear axle or Dana 60, both should be fine for your usage.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-18-2010, 11:09 AM   #4
1970CustomC10350
Thanks guys! Keep the tips and info coming. When you go to dump the the front drums is it a matter of swapping later model parts in or a kit or do you need to replace the whole front axle?
Old 04-18-2010, 11:42 AM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
replacing the whole front axle would be the easiest and about the same money. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-18-2010, 01:54 PM   #6
1970CustomC10350
Thanks again. We are off to go look at it and see what it is worth. Replacing the whole front axle is kind of a bummer though. It might be kind of hard to find a replacement donor vehicle. Hopefully it will have a good rear axle and transfercase anyway.
Old 04-18-2010, 01:56 PM   #7
milled
milled's Avatar
Go to a local you pull and pay to get a axle (or craigs list). next make sure to match the gears in the front diff to the rear, ie 4.56 to 1 or 4.10 4.10 raito. also take the ubolts and hardware. The years you're shooting for are 1971 thru 1987 3/4 ton or single wheel one tones .
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 04-18-2010, 02:54 PM   #8
Mike C
Mike C's Avatar
You can also use a Suburban 8 lug axle through '91 but you may need to swap the lug studs from metric to standard. I know they went to metric studs on pickups in '88 and the MIGHT have done the same on Subs and old body style trucks that were still in production through '91.
I have bought (2) different 3/4 ton parts Suburbans. $300 for the first one with a blown motor, and $200 for the second with a bad trans.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-19-2010, 12:17 AM   #9
1970CustomC10350
Well went and looked at it. Cant say I'm delighted. What left of the body is shot. The drivetrain and suspension is fairly complete though. It's missing the front driveshaft and rear shocks is all I noticed. It has an HO52 rear and what I think is a Dana 44 front with drum brakes.
Old 04-19-2010, 12:23 AM   #10
1970CustomC10350
I'm not sure what the transfer case is but I don't think it is a new process. Did Borgwarner make one for these trucks? It a manual transmission if that helps. If the guy will deal a little I think we'll drag it home. The Suburban thing is kind of funny. A year or two ago I scrapped a 3/4 ton Suburban. The gear ratios had to have been diffrent. Will they bolt right in or do have to move spring perches ect.?
Old 04-19-2010, 01:18 AM   #11
1970CustomC10350
I just figured out from previous posts on the board it has a Rockwell T221 transfer case. I was hoping for a new process. I'll have to do some more reading on it.
Old 04-20-2010, 11:48 PM   #12
1970CustomC10350
After a day or so thinking about it I think we will let this one go and hold off for a 71 or 72. It was a valuable learning experience though. Considering we might have to change the front axle and transfer case at some point, we would really not be getting alot for our money. The timing could be better as well.
Old 04-21-2010, 01:44 AM   #13
KrazyRay
KrazyRay's Avatar
I'm doing a similar project...a 72 2WD super on a 72 4WD custom frame. One thing to mention is while the body is off it is really easy to work on the drive train. If you put in a 700R4 out of a square body donor than you can run HEI without it being too close to the firewall. The 700R4 pushes the motor toward the front by a couple of inches. (The 4WD engines are set back 3 inches more than the 2WD). I'm not sure, but I think you can then use the 2WD fan shroud which is easier to come by.
KrazyRay is offline   Reply With Quote
Old 04-21-2010, 09:40 AM   #14
Mudder
Mudder's Avatar
We do have a forum here for 4x4 topics.
Mudder is offline   Reply With Quote
Old 04-21-2010, 09:51 PM   #15
1970CustomC10350
Thanks for the replies. Not trying to go out of bounds, wrong forum. I just figured my question and subject was more 67-72 truck specific than just a 4x4 general question. Thanks
