distributor cap problem i think?
popped cap off to check the cap to see if thats why i cant go over 70 on highway but in town driving is fine.. then i seen on my msd cap that there is a thin trace at the back of the cap thats a perfect ring around it maybe like 1/2 inch from the 4 holding clamps.. so i just wiped it off and called it good.. then i popped my accel hei super pack coil or whatever its called and you know that little rubber circle with the spring and the button lookin thing? that melted a little bit of that plastic stuff on my coil and made the connecting point kinda bronze color.. so i think i found my problem.. i assume thats it?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Junior Member
Re: distributor cap problem i think?
I am not sure your cap is keeping you from going over 70 mph, but from what you described I sure would replace it.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
