Old 04-18-2010, 02:03 PM   #1
walker_quiram
68 K10 Lift kit, tire size?
Wanting to lift my 68 K10 4 inches. What size tires do people recommend for that size lift??? I was thinking 33's or 35's X 12.5" wide. (Most likely Toyo MT's) Not sure if 35's will rub with a 4" lift. Any suggestions or comments?
walker_quiram is offline   Reply With Quote
Old 04-18-2010, 02:19 PM   #2
71GMCer
Re: 68 K10 Lift kit, tire size?
I too am thinking of lifting my truck. Its a 71' though and i believe it already has a body liift...i have 30inch wheels on mine (i just measure from bottom of the wheel to the top) I think if you get a 4'' lift you shouldnt really have to worry but im not quite sure.
71GMCer is offline   Reply With Quote
Old 04-18-2010, 03:35 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I had a 4" Rancho lift with 35" bfg's on 8" wheels, no rub. Other lift kits maybe less lift though. You will definitely have no problem with 33''s. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 04-18-2010, 07:01 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
^^^THATS A BEAUTIFUL TRUCK!! I wish my blue truck was 4x4
John
1999 Toyota Tacoma 4x4
Old 04-18-2010, 07:32 PM   #5
vectorit
What?
vectorit's Avatar
You do realize that the 67/68 suspensions are the red headed step child of after market suspension suppliers right? As far as I know there are no aftermarket dealers supplying suspension lifts for the 67/68 years.
I had to have mine redone at a spring shop that made springs for large trucks, and that was over ten years ago and today? doubt it.
Another reason to say WTF regarding parts houses that claim to be all that.
BTW. My rebuilds with an added leaf let me run 33x12.50's no problem.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 04-18-2010, 09:51 PM   #6
Mr-Jack
Beer Drink'n Knuckle Dragger
Mr-Jack's Avatar
Re: 68 K10 Lift Kit/Tire size????
most popular with a 4" lift would be 33's most go 35's with 6" lifts. i've heard that if you just do street/show with your truck...35's should be ok, but i go offroad so 35's and 6" for me. if i was staying 4" lift and planned on going off the street i would only go 33's
GOD BLESS MY BROTHERS & SISTERS THAT SERVE WITH US
- 67 GMC Long-Wide 350/SM420
My BACON Wrapped Meatloaf Recipe
Mr-Jack is offline   Reply With Quote
Old 04-18-2010, 10:14 PM   #7
knsmodels
I make Models
knsmodels's Avatar
since 33's fit on the stock suspension I would vote for 35's
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 04-18-2010, 10:48 PM   #8
msgross
msgross's Avatar
not always true though... depends on rim size, tire width and backspacing.... also how tired your springs are... I do have 33x10.5 on stock springs...
35's will be close.. 33x12.5 fit nicely though...
ditto on the 68 springs options, maybe try a rear shackle flip and new front springs.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-18-2010, 10:51 PM   #9
msgross
msgross's Avatar
please only post this in one area... I moved your other thread into this section..
The Garage:
Old 04-18-2010, 11:04 PM   #10
walker_quiram
I'm just going to buy all new springs and do it that way instead of blocks. I have heard that the 67/68's are a pain to lift but it has mostly to do with the steering shaft and the frame I have has the updated steering box already on it and the guy that is doing some of the work for me says it is no problem and he has been around chevy's his entire life. As far as offroading goes, my pickup will not see more gravel roads than my half mile drive way. Way too much money invested to take this thing and mess up the paint job and all other work that's been put into it. The rims will be 18's, and wasn't thinking of having any offset. I don't think 35's will be a problem, just more money! Thanks for the pic Trevor.
Old 04-19-2010, 12:57 AM   #11
Mr-Jack
Mr-Jack's Avatar
i have the most un-orthodox lift / suspension parts for a 67 longbed sitting in my garage right now. all parts to lift except the shocks and new drive shafts that i'll get after i get the stance figured out. i ordered from about 5 or 6 differant companies. if my calculations are correct about 7" lift on 35's and upgraded stock steering with the push pull j-arm. it's going to be an adventure to say the least. should be starting this in about a month. just waiting on my plane ride home. good luck with the lift
Old 04-19-2010, 07:17 AM   #12
I run 12.50/33s on 10" rims and very tired springs on my`72 K2500.With good body mounts you can run 12.50/35s and a 4" lift and 8" wheels.If you wheel really hard they can rub as well as many other numerous ways to damage the truck.If you wheel it that hard you might just want to cut the fenders.I either wheel`em or keep`em pretty.The keep`em pretty trucks run 4"/35s/8" wheels/uncut fenders.
Your buddy must not know that there are no off the shelf lift kits made for pre-69 GM 4wds.The springs are wider.I`ve known guys to put spacers between the spring eyes and the hangers.
Old 08-10-2010, 09:36 PM   #13
coggonobrien
what's the wheel size/backspacing. also any concerns with the drivershaft u-joints pre-maturely wearing out with that much lift? finally are the driveshafts stock length?
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 08-14-2010, 08:01 AM   #14
silver7
silver7's Avatar
33s would be best for a 4in lift. 31s would look too small and 35s would be a tight fit and might rub.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
