04-18-2010, 03:30 PM | #1 |
ready to ditch my Qjet, Which Holley is ideal?
Well as the title says I am just one of those people that think the quadrajunk is too overly complicated and is just not suited for my particular vehicle. First let me tell you whats on my 70' burb right now. It is a qjet off of an 83' C10. I have looked it over again and again and I just don't have the patience for it. I have finally put my foot down and I am switching to a holley carb. Right now I'm eye balling a 670 street avenger elec. choke but the engine in my burb' is a pretty tame 350 with a 700-R4 overdrive. Would a 570 be better for my burb'. I would also like to get the best fuel economy out of this truck while cruising and part throttle driving. and one more thing to consider is that I have to drive up and down a hill to get from town to my house which is an elevation change of 2,500 ft so tuneability is a big factor here. Basically what it boils down to is 1 Fuel economy 2 low end torque 3 tuneablilty 4 less headaches (actually that should be first)
04-18-2010, 06:32 PM | #2 |
Re: ready to ditch my Qjet, Which Holley is ideal?
edelbrock is the best choice for your application. Fuel milage and a holley is not likely. a 600 is ok for a mild 350 unless you drive the crap out of it.
formerly cooter |
04-18-2010, 06:47 PM | #3 |
Shake and Bake!
Holley makes a nice carb, but if you want clean, simple and affordable than Edelbrock is the way to go IMO. There really isn't much to them, easy to work on, tune and fix. Although I haven't had a Holley on anything since my 67 Camaro and that was back in 96.
Its all preference.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
04-18-2010, 06:53 PM | #4 |
X3 on the Edelbrock install, set it ,forget it. Jim
04-18-2010, 07:00 PM | #5 |
What?
80 something Q-jet on a 70 something motor, hmmm yea issues there already.
Q-jet more complicated than a Holley? Debatable. I agree with all the others, and go with the Edelbrock carb. I ran one for years, and yea it is pretty much a bolt in, hook up, and forget carb for a driver. You won't be disappointed with that set up, which is more than I would say for Holley as a DD carb.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-18-2010, 07:06 PM | #6 |
Between Trucks...
Yet another vote for the Edelbrock. Try a #1406, the tuning kit is nice to have too.
Beat it to fit, Paint it to match... |
04-18-2010, 08:26 PM | #7 |
Junior Member
I have a Q-jet on my 454 in a '71 C-10 and am ready to switch to something else.
My brother swears by Holley and my son says Edelbrock is the only way to go. From what I have heard on this forum people like Edelbrock better, now all I have to do is figure out which model to go with. The 454 is pretty much stock with an RV cam and headers. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-18-2010, 08:27 PM | #8 |
Be perpared to use more fuel, nothing beats a q-jet for fuel econ. i would find a 70's q-jet for your engine.
04-18-2010, 09:00 PM | #9 |
i bypassed all the flashy holley JUNK and went straight with a reman'd q-jet for my 72 burb induction upgrade (stock 2bbl). the q-jet handled all those GM muscle cars back in the day and it flows more than an entry level holley or edelbrock carb for less money (why pay more for less?) i do have an edelbrock intake under my carb (idle-5500rpm range) for even better throttle response and torque. "holley" and "ideal" do not belong in the same sentence, but edelbrock does make an decent q-jet knockoff. spread bores forever!
04-18-2010, 09:28 PM | #10 |
resident oilfield trash
Thats funny I am going from a new Holly to an old rebuilt Qjet on my 396
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-18-2010, 09:30 PM | #11 |
Between Trucks...
I actually picked a couple of mpg when I went to an Edelbrock, though I tuned it and didn't really touch the Quadrajet it replaced.
04-18-2010, 10:24 PM | #12 |
Location: Help! I'm in an office park with its own network of freeways!
Sadly, Edelbrock stopped making them a few years ago.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
04-18-2010, 11:33 PM | #13 |
Instead of paying for a holley that would also require alot of tuning, SMI (sean murphy induction) will rebuild your q-jet to your engine specs for 180$ and fix all the common q-jet problems
'72 cheyenne super step, '05 long bed gmc |
04-18-2010, 11:43 PM | #14 |
wow, I really appreciate everybody's input. I definately wasn't expecting to hear so many people in favor of the edelbrock carbs. I will definately have to look over my options with edelbrock. One of the big things I'm worried about is the fact that I have to drive up and down a hill that has an elevation change of 2,500ft any pointer as to how I can get the best out of a carb when I'm changing elevation so frequently.
Lastly which edelbrock carb would you recommend. I'm not going to drive the wheels off the burb' It will rarely see 5,000 rpm and I just want a reliable, dependable, smallish carb. |
04-18-2010, 11:55 PM | #15 |
I would recommend an Edelbrock 1406 as well, seeing as you have quite an altitude change in your commute. They're fairly simple to setup and once you've done that, it can pretty much be forgotten about.
The holley would be a lot more finicky... you'd have to baby it by constantly tuning it to get what you want out of it. Holley's are good for the drag-strip though. Of course as a few have said here as well, a properly tuned q-jet surpasses the advantages of both edelbrock and holley... and has none of the disadvantages. |
04-19-2010, 12:09 AM | #16 |
I'm gonna be the lone Holley guy. The Street Avenger is a great carb. I would much much rather have it than an Edelbrock. I have a ZZ430/700r4/3.73/26" tire in my 79 Elco with a 770cfm Street Avenger that gets 16-18mpg. Just my 2 cents.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
04-19-2010, 12:18 AM | #17 |
The edelbrock 1406 is looking pretty good from all the carbs I've been looking at. For anybody who has used one, would I be able to get the carb to hook up with the TV cable for my 700-R4. I just don't want to put good money down just to find out I have to take a couple more trips to the parts store.
04-19-2010, 08:59 AM | #18 |
I HATE Edelburp carbs. I would rather have a leaky Q-jet than one. After 4 bad Edelbrocks, I now have the Holley 570 SA and LOVE it. I get decent mileage and runs ALOT better than any Edelbrock I've ever had.
I say go with the 570 Holley.
04-19-2010, 09:54 AM | #19 |
If you chose the Holley or Edalbrock you will need on of these.
http://www.summitracing.com/parts.aspx?sku=EDL-2732 And you will need one of these for the Edelbrock. http://www.summitracing.com/parts/BMM-64511/ And one of these for the Holley http://www.summitracing.com/parts/HUP-HP8625/ Just some more reasons to stay with the Q-Jet
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
04-19-2010, 10:01 AM | #20 |
Old Duffer
I have to vote Edelbrock. I put one on my 292 and right out of the box it was good to go. All I had to do was set the idle RPM.
As for the Holley, they don't tolerate "sneezes" very well, the power valves suffer from them. They have to be taken off the engine to be tuned, (An Edelbrock's rods and jets can be changed on the engine with no gas leakage)and Holley having gaskets below the fuel level sorta bothers me. JMO
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
04-19-2010, 10:11 AM | #21 |
my truck came with an Eldelbrock 1406. was put on about 10 years ago. still runs smooth with plenty of power. 350 V-8 with matching manifold
04-19-2010, 01:35 PM | #22 |
Well I ordered the 1406 edelbrock this morning with the spreadbore to square bore adapter plate. I asked the representative on the phone about any special parts for the 700-R4 and he said that I didn't need anything. but after looking at those links it looks like he was wrong.
when it comes to the 700-R4 if I left the TV cable disconnected at the carb would that mess up the transmission. I know that if it's improperly adjusted that it can do some serious damage really quick. |
04-19-2010, 01:55 PM | #23 |
Moderator
Edelbrock 1406. Done. I bought one from a boardmember here and he told me it had been sitting on a shelf for 10+ yrs. I bolted it on and have been running it ever since. Zero issues.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-19-2010, 02:02 PM | #24 |
You cant leave the TV cable disconnected at the carb because it controls the pump pressure. Its not like the cable for a turbo 350
04-19-2010, 02:09 PM | #25 |
I've been on the phone 3x this morning with the summitracing people. first I ordered the carb and adapter plate, then I ordered the B&M throttle kickdown linkage, THEN... I looked in the catalog and found an Edelbrock throttle linkage adapter for kick down cables for 1/2 the price of the b&m unit. So I saved myself $20, Feels so good!
