Old 04-18-2010, 03:41 PM   #1
dgodecke
dgodecke's Avatar
Has anyone gone from 4WD to 2WD?
I have a 73 GMC SWB 4WD and looking to get read of excess weight so I thought the NP205 and frond end would be a good place to start.
I already have a 4WD truck and have no plans of ever taking the 73 off road. I also want to lower it a bit. I have to replace the transmission anyway from a TH350 to a TH 400 to hold the 454's power.
Has anyone done this conversion? What kind of problems did you run into?
What did you do to located your upper and lower A-frames on the frame?
What about the trans cross-member any suggestions?
All ideas and suggestions are welcome.
07 Chev 2500HD Classic
Project Ranch Hand, Hauling A$$ since 1973
I was told this Project had a L-72 427 425HP, It did not.
It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end.
It has not been run for 20+ years
Frame up restoration started2/15/2010
dgodecke is offline   Reply With Quote
Old 04-18-2010, 03:48 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Has anyone gove from 4WD to 2WD?
I'll have to see if I can find the thread, but yes it has been covered. Your best bet would be to locate a 2wd donor to swap all the parts you need. That will give you a 2wd front crossmember, suspension, and steering. That's the bulk of it, along with the crossmember you mentioned.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
