Old 04-18-2010, 04:52 PM   #1
Hair
fuel pump install?
Is it possible to put the fuel pump in wrong on a 250 strt 6?
I aint gettin no gas out of the pump.
I take the pump off and cover the outlet end end with my finger and pump on the lever and it builds up air pressure, so I figure it's good. Then I put it back on and nothing.
The pump was working fine when I took it off two years ago and put it on a shelf and then put it back on and now it aint working. Unless I'm puttin it in wrong.
I know on some engines if you don't get the dog leg in right on the cam lobe it will not work, but from what I can tell, you can't mess up when installing the pump on a six.
Could the pump be bad... even if it build pressure when I pump it by hand? Maybe I'm pushing it farther than the cam and it's worn out or something?
Suggestions??
Hair is offline   Reply With Quote
Old 04-18-2010, 05:13 PM   #2
bean
Re: fuel pump install?
I think you may have to break down and buy a new pump
bean is offline   Reply With Quote
Old 04-18-2010, 05:18 PM   #3
Leviticus
Shake and Bake!
Leviticus's Avatar
If you do replace it, i'd go with an electric pump. I love mine.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 04-18-2010, 06:15 PM   #4
cdowns
cdowns's Avatar
the lever needs to b on top of the cam lobe for the pump to work
Old 04-18-2010, 06:22 PM   #5
Hair
Yeah, I know it needs to be on top of the lobe on a v-8 but on the six it is sideways and as far as I can tell you can't mess it up... but I don't know... this is the only six I've ever messed with.
So is there a certain way to put it on a six? The cam is beside the lever, not on top, as far as I can tell.
Old 04-18-2010, 06:50 PM   #6
292farmer
292farmer's Avatar
your line to the pump has no holes right? if so it might just be sucking air, did that on my 86 bought new fuel pump only to realize a line was completely snapped on frame halfway between tank and pump, so wasnt sucking fuel.(that was a 350) did the fuel pump on my 292 last month just stuck it in and bolted was nice not having to fuss w/ pushrod lol worked fine right off the bat. ive heard pumps can go bad sitting the diaphragm i think?
292farmer is offline   Reply With Quote
Old 04-18-2010, 07:02 PM   #7
Hair
Yeah, I'm starting to think that it is the pump.
I've thought about a bad hose, so I ran a new hose to a jug of gas and still nothin.
I have put the pump in and out 4 times now and I know for sure the last time it is being pumped, because I left it a little loose and watched it push the pump in and out as I cranked it and then just tightened it up. Let the truck idle while I squirt gas in carb with a squirt bottle and it never pumps any gas.
I'm going to try a new pump I just wont be able to get one until tomorrow
It just makes me think that the pump is good because I can work it by hand and it will build up air pressure. However when I hook a hose to it and pump it by hand to suck fuel out of a can I get nothing... so anyway I'll try a new pump. I just wanted to get it running today
