Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-18-2010, 05:30 PM   #1
Tony_SS
Tony_SS's Avatar
Question No Power to the Head unit
I've done install a few times, but cant figure this out.
I have all the speakers hooked up.
I go to run power, straight from a 'PWR' open terminal to the power wire to a Sony head unit and I get nothing. Unit is brand new.
I've tried it a dozen ways from the fuse box and can figure out the accy / power hookup?
Once I did get the CD player going, but no lights. I just need the power/accy/ground wire hooked up, right?
Tony_SS is offline   Reply With Quote
Old 04-18-2010, 06:27 PM   #2
Tony_SS
Tony_SS's Avatar
Re: No Power to the Head unit
Update: Got power, works fine, but memory doesnt work.
I ran a straight line to the IGN and it worked, but then when I unhooked it to reroute the wire, hooked it back up again and now it wont save the data...
ugh.
Old 04-19-2010, 02:35 AM   #3
AceX
>130dB Moderator
AceX's Avatar
Losing the memory? Hmmmm... A constant (power supply) should solve the issue. Maybe try and switch the wire to the cig lighter.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-19-2010, 09:37 AM   #4
Tony_SS
Tony_SS's Avatar
Got it worked out.. not sure how, but it works. I switched power from the factory yellow and constant from an open red slot in the fuse box. Works great.. love my new $100 Sony head unit.
