Old 02-10-2001, 08:08 PM   #1
Jamie
Post 1981 C10 Brake Bleed problem
My brake warning light went on a few weeks ago. The only symptom of failure was that the truck would pull a little to the left on braking. Otherwise, no leaks and the master cylinder seem to check out okay. In an attempt to solve the problem or make it show itself again, I decided to simply bleed the system and hopr that the brake warning switch re-set itself. No such luck. In the midst of bleeding the right front caliper, no fluid came out.
I have read that in power bleeding the system after the warning light has come on, the proportioning valve will actually shut a circuit down. Is this your experience?
The instructions that I've found in Clymer's for re-setting the plunger/switch are confusing and do not match the proportioning valve in my truck (probably written by someone who has never done the work). Does anyone know what I can do? Help!!!! Thanks in advance.
Jamie is offline   Reply With Quote
Old 02-11-2001, 12:52 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Post
Hi Jamie,
I replied to your post at Chevytalk
After reading this one, I believe you have a brake line collapsed or plugged.
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Site
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-11-2001, 07:14 PM   #3
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Post
If it pulls to left the problem is somewhere on the right front check for a ceased caliper I had the same prob on my 73 Jimmy 4X
71 Custom/10 lb fleet .040 over 350/th350 good ol 1 wheel peel 3.73 12 bolt 275/60/15 all the way around on late model SS wheels
[This message has been edited by Burlinator (edited 02-11-2001).]
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
