Old 04-18-2010, 08:41 PM   #1
javadoc
Hey Watch this...
javadoc's Avatar
Stepside Tire Size?
Spring is here, and this summer's project is the truck. The first order of business is to install the 3/4 (or 5) drop. However, I know that the rear wheel/tire combo is not going to work once the truck is dropped. I currently have 15x10 chrome smoothies with 295s in the rear. When loaded, they rub. Badly. IIRC, they're 4" backspacing.
I have measured the inner area of the rear wheel wells and it looks like I have right at 12" of width under there, between the bedside and the inner edge of the step fender.
So, my question is, what size tire are people typically able to fit on the rear of a stepside? I'm probably going to have to ditch the 15x10s... but I really don't want to if I don't have to.
Thanks guys, for the wisdom!
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 04-19-2010, 11:24 AM   #2
bobcostas
bobcostas's Avatar
Re: Stepside Tire Size?
I'm running 225-75-15's all the way around on 15x6 smoothies. but i like narrow tires.
i took off 265-75's on the rear when i got my new shoes. there seemed to be plenty of wiggle room with them if you like the wider variety.
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 04-19-2010, 01:43 PM   #3
austex66
austex66's Avatar
I'm runnin 235/75/15 on stock rim (5" BS?) with a 6" drop, and not much room left on the fender side. Maybe a different back space will allow more tire?
66' Chevy SWB:350ci-th350,frt. disc brakes, pwr steering, 5-lug
waltshow.com/Chevy
austex66 is offline   Reply With Quote
Old 04-19-2010, 02:05 PM   #4
steveb64
steveb64's Avatar
I'm using 255 75x15 tires with 8" rims, fit is about right, no rub, space on both sides.
steveb64 is offline   Reply With Quote
Old 04-19-2010, 05:31 PM   #5
Russ65C10
Russ65C10's Avatar
I have 265/70R15's on 8 inch rims. No drop and no rub. I ran G60/15 in high school bias plys where fine with a load but my GT Qualifiers rubbed big time with a full load.
It seams that 265 is about as big as you can go once the tire spends any real time up in the fender well.
Russ65C10 is offline   Reply With Quote
Old 04-19-2010, 08:08 PM   #6
javadoc
Hey Watch this...
javadoc's Avatar
Awesome, thanks guys. Now to find a decent 265 tire... 8" rims, and sell off the 15x10s.
Old 04-19-2010, 08:50 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Here are two pics of the rear tires/wheels on my short stepside. The early photo shows 8" rims with 235/70-15's, and the later photo shows 255/70-15's on 7" rims. Both wheels were zero offset. Although my truck isn't lowered, I've had it loaded enough to drop the fenders over the tires and I've never had any clearance issues with 7" or 8" rims as long as the back spacing equals the front spacing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-19-2010, 09:59 PM   #8
javadoc
Hey Watch this...
javadoc's Avatar
I really like the truck in black. Super clean.
Old 05-27-2011, 10:56 PM   #9
First66
First66's Avatar
There has to be more info about this now.
I'm looking to get a wide tire/rim combo on
my stepside '66 with stock rear end. I will be dropping the the truck at least 3" all around, probably more in the front.
Any pics of the of stepsides taken from the rear so the tire meat shows would Greatly be
appreciated. Tire and rim sizes coincinding with pics would be Phenominal!
Oh yeah, Backspace too!
First66 is offline   Reply With Quote
Old 05-30-2011, 02:39 AM   #10
javadoc
Hey Watch this...
javadoc's Avatar
I ended up with 15x8's with 3.25" back spacing. 245s on the tires, and they fit about 'perfect' in my opinion. Ready for the 3/4 (front/rear) drop that I have planned!
Old 05-30-2011, 08:34 AM   #11
lakeroadster
When I originally purchased my truck it had 31 x 10.5 x 15 rear tires and stock 8" wide truck ralley's which have 3-1/2" B.S.
(Ideally, for a budget build, a guy could use some custom offset steelies with a lot of backspacing... these stepside beds are narrow compared to a fleetside. And without inner wheel tubs the inner bed wall reduces the amount of tire width too.)
I wasn't at all happy with the look from the rear of the truck. I didn't want a pro-street look, but those 31x10.5's weren't enough rubber. That's why I ultimately decided to widen the bed 4" and make some mini tubs.
With the wider bed I am running rear 15 x 8-1/2 Indy Aluminum Slots and front 15 x 7 Western Aluminum slots. Rear tires are 33x12.5x15; fronts are 235-75-R15. Even with the widened bed I still ended up flattening the lip on the fender for additional clearance. But I like the look of the tire close to the fender....
Classic “Big & Littles”:
lakeroadster is offline   Reply With Quote
