Old 04-18-2010, 10:20 PM   #1
dbmx66
bolt circle question
i got a set of rims for my buddies car, but i dont know what the bolt circle is.
they are a 5 lug rim. they are a chevy pattern. wehn i measure from the center of one the holes to the center of the other hole after i skipped a hole, its comes out to be 4.5 does this mean its 5x 4.5?
dbmx66 is offline   Reply With Quote
Old 04-18-2010, 11:19 PM   #2
country29
Re: bolt circle question
yes. on 5lug wheels measure center of 1st hole to back of 3rd hole gives you the bolt circle. all 5lug 73-87 are 5x5, those wont work. most gm cars are 5x 4.5 or 5x4.75. hope this helps.
country29 is offline   Reply With Quote
Old 04-19-2010, 07:43 AM   #3
grinch4om
dang its hot
grinch4om's Avatar
all GM cars are 5x4.75 or 5x5
grinch4om is offline   Reply With Quote
Old 04-19-2010, 10:49 AM   #4
nlped
nlped's Avatar
That would only work on a four lug wheel. The "bolt circle" is measured from one side of the "circle" that runs directly through the center of all the bolt holes on the wheel, whether its 4 lug or 12 lug.
If the wheels came off of a Chevy car, they are 5x4.75" most likely. You can actually measure from the center of one bolt hole to the center of the next bolt hole and calculate the diameter of the bolt circle that way. Take that measurement, we'll call it "BC", and do this simple calculation...BC/.588, and you should get the Bolt Pattern.
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-19-2010, 03:34 PM   #5
dbmx66
they are weld draglites off of 67 nova pro street. but it didnt have the original suspension under it.
Old 04-19-2010, 03:35 PM   #6
dbmx66
these arent going onto the truck
Old 04-19-2010, 03:38 PM   #7
nlped
nlped's Avatar
I can't actually think of a gm rear drive car that ever used 5x4.5" bolt pattern. The nova would be 5x4.75". But those draglights should be dual bolt pattern (I.e. 10 hole)
Carter
Old 04-19-2010, 04:03 PM   #8
dbmx66
ones a chevy pattern, ones a ford, but i measured the center to center, do i measure from the center of one to the outside of the other? when i do that i get 4.75
Old 04-19-2010, 07:52 PM   #9
country29
Cool Re: bolt circle question
Ed
I'm not disputing what you are saying, I do not know all nor will I, but if i take a tape measure and measure a 5 lug wheel from center of 1st to back of 3rd hole i get the bolt circle everytime. plus look in the summit catalog they tell you how to measure 4/5/6/8 lug wheels that way. just my .02
Old 04-19-2010, 08:10 PM   #10
LONGHAIR
Words and pictures....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-19-2010, 08:24 PM   #11
dbmx66
so if the measure of the yellow line is 4.75 that means its 5x4.75
Old 04-19-2010, 08:37 PM   #12
country29
thank you longhair, and i did misspeak on the 5x4.50 cars were 5x4.75. the mind just doesn't work like it use to! lol
Old 04-19-2010, 08:38 PM   #13
country29
yes.
Old 04-19-2010, 11:35 PM   #14
dbmx66
thanks you sir
