Changing rod link shift to cable shift on column
Has anyone ever made an attempt to swap their shift linkage to cable linkage like the newer vehicles come with.
Well I just got through converting my 65 GMC from rod linkage to cable linkage and let me tell you it works great. I'll try posting pics later. |
Re: Changing rod link shift to cable shift on column
I have been thinking of doing that...........Pics would be great.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
ill be doing this in the next week or so. Ill make sure to take pics.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
Yes, very interested!! I was comtemplating buying the kit from Lokar, I never even thought of using what the new vehicles use.
![]() What year donor? You sir, made my day, subscribed. ![]()
Don't let my username fool you, I have become brand blind. Cool is cool, period. ![]() 1965 C-10 - "Whipping Post" 1958 Biscayne - "Ruby" 1961 IH Scout 80 - "Gaucho" (My wife's new project) 1938 Chevy - unstarted project. |
OK,some pics of the install.Hope you can make something out of them.What I used were the cable and trans link bracket and trans cable bracket from a 98 S10 Blazer.The column link bracket and column clamp I fabricated.
One more pic.
Registered.........
Very Nice! I used the Lokar kit for mine, had it installed for over two years now. I had to modify the set up as it was for a 67 and up application - after installation my shifter operated bacwards (park was first, reverse was second etc..). After I figured out a solution, man what a difference - precise gear selection every time with no hang ups!
That being said, I sure wish I had thought of or seen a cable set up off of a newer truck, there's nothing like factory parts for ease of maintenance and replacement parts. Great job!
1966 C10 panel-400 small block/TH 350 combo Nothing is fool proof to a talented fool! Popcorn: Pops at exactly 444 degreese Expands to 44 times it's original size Has a 4 year shelf life Last edited by wild one; 04-20-2010 at 12:15 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Nice job low79fx
Is that an original auto column in your truck?
#9 | |
One thing I do have to admit is that the shift arch is not wide enough as I can only get it to drive gear,I will have to redo that column link and increase arch angle to give it more swing to be able to get into 1st & 2nd gear.But for now it works great,and yes for the gears it does hit,it is dead on.What a difference. |
