Old 04-18-2010, 11:25 PM   #1
harnalien
TruckincrazY
harnalien's Avatar
Front end rebuild with new brakes
I just redid my front end. All new tie rods and centerlinks, new bushings, new ball joints, and new rotors and pads. This job sucked!! The truck rides a lot better though so it was worth it. Hope y'all like!
harnalien is offline   Reply With Quote
Old 04-20-2010, 08:13 AM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: Front end rebuild with new brakes
As info, these are summit brand rotors
Old 04-20-2010, 08:24 AM   #3
Turbo85GMC
Turbo85GMC's Avatar
Looks Nice!
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-20-2010, 09:10 AM   #4
78BO
78BO's Avatar
Yea, it sucks! I did the same thing to mine. I have noticed that one of my lower ball joints will pop out when I jack it up and take the spring pressure off of the lower control arm (I've got 3in drop springs). I was thinking of replacing it, but I'm wanting to upgrade the controle arms first.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 04-20-2010, 09:53 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 78BO View Post
Yea, it sucks! I did the same thing to mine. I have noticed that one of my lower ball joints will pop out when I jack it up and take the spring pressure off of the lower control arm .....
Sounds like your asking to get stranded beside the road. If you have that much play in the ball joint, it's going to either fail, or pop out when your driving.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-20-2010, 09:55 AM   #6
silvereagle07
silvereagle07's Avatar
Looks good. What brand suspension kit did you use? I'm about to do the same to my 84.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 04-20-2010, 10:33 AM   #7
78BO
78BO's Avatar
Yea, I know. I forgot to say it's when then nut is backed off too. It does stay in place when the nut is tight. But in the end, I only drive it on the weekends (sometimes). So it should be able to last untill I can buy the controle arms I want.
Old 04-20-2010, 02:34 PM   #8
swb85
On a budget like Fred Sanford
swb85's Avatar
I reeeeeeally need to do this to mine, everything but the brakes/springs is shot. What's it generally cost for all the parts for a front end rebuild?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-20-2010, 02:51 PM   #9
kevinr1970
I just had this done on my crew; converted from 3/4 to 1/2 ton.
All parts were close to $1000 but we did everything.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 04-20-2010, 04:09 PM   #10
78BO
78BO's Avatar
upper and lower ball joints= 100
upper/lower control are bushings=65
inner/outer tie rodes=300.00 for the kit at jegs (I think you can get them cheaper at autozone).
100 bucks for cleaning rags lube and beer (you'll need the beer!), and if you are stupid like me, 300 bucks to have someone press the bushings for you!!! They are pressed in and a mother to get out. I couldn't get them with a air hammer.
And last the alignment. I paid 100 something for a 3 year.
Old 04-20-2010, 05:40 PM   #11
harnalien
TruckincrazY
harnalien's Avatar
I used DJM 3" drop spindles and 2" shackles. I have some 2" hangers, but have not got up the courage to try and do it. The hangers are gonna be a pain.
Old 04-20-2010, 05:45 PM   #12
harnalien
TruckincrazY
harnalien's Avatar
I went to o'reilly's and bought my stuff. I don't drive this truck that much, so stock replacement was fine. The outer and inner tie rods were $12 a piece, and the 2 center links were $7. Shocks were $21 a piece. The idler and pittman arm were fine. The pads were about $30. I used energy suspension poly bushings and they were $55 through summit. I took my control arms off myself and took them to the shop to get the bushings and ball joints done...that cost me $100. I also had to pay to get the alignment done after everything.
Old 04-20-2010, 06:52 PM   #13
87 chevy silverado
i was wondering is your truck a silverado or a scottsdale?
87 chevy silverado is offline   Reply With Quote
Old 04-20-2010, 07:05 PM   #14
harnalien
TruckincrazY
harnalien's Avatar
It's an '84 silverado. Light duty brakes.
Lol, I didn't realize the fender emblems showed. The passenger side fender came from the junkyard due to some minor damage.
Old 04-20-2010, 08:27 PM   #15
78BO
78BO's Avatar
Seriously, the hangers are easy. Time consuming, but easy. I did mine in the garage. Drop the gas tank first. Jack it up as high as you can.
Buy a good big face shield, gloves, and something leather to cover your arms, and a grinder. Grind off the heads to the rivets, once you can see the outline of the hole get a drill and drill out the center of the rivet. Then punch them out. DONE!
