Old 04-19-2010, 12:28 AM   #1
paul66c10
paul66c10's Avatar
upper ball joints
ok im fighting my upper ball joints whats the easiest way to get the factory upper balljoints out i've grinded the heads off the top and have been try to beat the rest of it out but its not moving lol... any tricks to do this? 1st time messing with chevy ball joints im used to just pressing them in and out like the lowers
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 04-19-2010, 12:44 AM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: upper ball joints
what i did was grind the heads off till you see the hole where the rivit went into the factory ball joints. Then i drilled them out using cobalt drill bit and got a punch and punched them out. It was a pain but got it done good luck man.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 04-19-2010, 12:58 AM   #3
harnalien
TruckincrazY
harnalien's Avatar
I just took my control arms off and took them to the shop! Of course I was having the bushings done at the some time.
harnalien is offline   Reply With Quote
Old 04-19-2010, 10:56 AM   #4
HumbleChevyBuddy
HumbleChevyBuddy's Avatar
I just did mine last weekend and did what 54Caddy said. It took a little bit, but it worked. On the passenger side I used an air chisel with a compressor. It was a LOT faster, but I had to go out and buy the right tools.
Good luck!
HumbleChevyBuddy is offline   Reply With Quote
Old 04-19-2010, 11:14 AM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I have found that using a dremel to slice slices through the top of the rivet then using a good chisel to chop off the slices.. i try and make em like a 16 or 8th of an inch and it goes quick
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-19-2010, 11:22 AM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
On both of mine, I pulled the UCA, put it in a vice, and ground the heads off the rivets. Then a friend of mine and I took turns beating the rivets out with a hammer and punch. It was a LOT of work.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-19-2010, 12:50 PM   #7
JNJchev77
Registered Cruiser
JNJchev77's Avatar
It's as simple as that!! ^
JNJchev77 is offline   Reply With Quote
Old 04-19-2010, 01:12 PM   #8
nlped
nlped's Avatar
I took the UCA off the truck, grinded the head of the rivet until I could see the hole in the UBJ and popped the little ba$terds out with a press. Went really smooth once I got in a groove.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-19-2010, 03:25 PM   #9
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
i used a seperator tool from harbor freight, it worked pretty damn good;. i think it was like 15$
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 04-19-2010, 03:30 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
After grinding the heads off, I use an air chisel with a punch tool in it. MORE POWER!!!
Frank
piecesparts is offline   Reply With Quote
Old 04-19-2010, 08:05 PM   #11
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Use goggles!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-19-2010, 09:23 PM   #12
westofb
I really hate wet sanding!
westofb's Avatar
X2 Just did it today, I used a 3" air cut off saw, cut x's in the top side, cut off the top with the air chisel then drove out the remainder of the rivet with the punch tool for the air chisel. I would recommend hearing protection if you use thus method, echoes pretty loud in the fender well!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 04-19-2010, 11:39 PM   #13
paul66c10
paul66c10's Avatar
thanks guys i did mine today also grinded the heads off and used a drill to drill most of it out then i used a BFH to beat the rest of the rivet out . now to actually install my 5/7 drop kit...realized i have more grinding and beating out back to install my c notch lol
Old 04-20-2010, 10:12 AM   #14
78BO
78BO's Avatar
This is what I did too. It worked great for me. Can't beat power tools!
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 04-21-2010, 12:32 AM   #15
wayfastwhitey
right below above average joe
wayfastwhitey's Avatar
i got lucky (except for the fact that my passenger upper ball joint broke while i was driving) and the ball joints were already aftermarket so all i had to do was un bolt them
i flush the of weakness with mushroom clouds at hand
'95 short bed x cab c1500...
just another old truck someone else beat up, abused, hacked and didnt respect... my turn to turn it into a beat up old truck into a beat up and reliable pleasure to drive...
them- "when you gonna put an exhaust on that thing?"
me- "what do you mean? The exhaust comes all the way to the bumber and sounds great!"
them- "straight pipes isnt an exhaust man..."
me- "meh... who needs a fancy muffler when you've got straight pipes? its got a cat, doesnt resonate, and I like how it sounds, and to be perfectly honest, it makes me behave myself when I'm out and about!"
^^^ favorite conversation about my truck to date
wayfastwhitey is offline   Reply With Quote
Old 01-05-2011, 06:00 PM   #16
goatwrangler
im getting ready to do upper and lowers on my beast this weekend but mine are factory, oh how i wish the uppers were after market. I dont have an air compressor strong enough to run my air tools.
Jason
1989 Crew cab 2wd 8 lug and staying that way
88M 638th ASB Lafayette, IN
goatwrangler is offline   Reply With Quote
Old 01-05-2011, 06:16 PM   #17
benoit454
Chris
benoit454's Avatar
We done a front end rebuild on dad's 84 back in nov. only air tool we used was the impact for the balljoint press we rented.
As for the tops I ground em til I saw the round spots, then just took a hammer and screwdriver between the balljoint and control arm to seperate them. I heard that after grinding the heads off a air chisel with a punch bit works great and very fast. I tried it by hand but without holding the upper down it just bounced, maybe ratchet strap it down and hit it. Or just take it off, it's only 2 nuts and then the brake line holder's bolt.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 01-05-2011, 06:22 PM   #18
goatwrangler
Thanks Benoit
Jason
