Old 04-19-2010, 10:57 AM   #1
l79m20
Blo-in smoke blues
When I start my in-line 6 I get blue smoke from the tail pipe, clouds of it but within a few short minutes smoke disappears and motor runs fine. My thought is that this is a valve guide issue but was wondering if anyone had any other thoughts. To my knowledge this motor has not been rebuilt. Thanks in advanve for all /any help.............Kirby
l79m20 is offline   Reply With Quote
Old 04-22-2010, 12:47 AM   #2
srr
Re: Blo-in smoke blues
You could try replacing the valve seals. This can be done with the head still on the engine.
You could also check to see if your drain back holes in the head are clear allowing oil to go back to the pan.
srr is offline   Reply With Quote
Old 04-22-2010, 04:37 PM   #3
l79m20
thanks for the reply will check when it stops raining...............Kirby
