67-72 trailing arms
i have a 70 gmc 3/4 ton with leafs and am planning on putting trailing arms-
i want to run front/rear sway bars also my question is do all the stock/factory trailing arms have sway bar mounts? i know the sway bar mounts to the trailing arms so thats why im asking and im not a half ton fan, so i have not seen a lot of trailing arms to know for sure. (FYI i know some 3/4 tons came with trailing arms)
1970 2wd ![]() ![]() ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 67-72 trailing arms
No provisions for rear sway bars on factory GM trailing arms. You are either going to have to drill or weld something depending on what sway bar you install.
