04-19-2010, 01:45 PM | #1 |
Doors or fenders on first?
Do the doors go on first and then the front fenders or vis versa? I think if I put my fender on first, then I can't get to the door hinge bolt... correct?
I'm thinking: put door on first and get set right with the rocker and cab, and then go from that to install and align/shim my fender. Is that correct? |
04-19-2010, 01:47 PM | #2 | |
Re: Doors or fenders on first?
04-19-2010, 02:11 PM | #3 |
if you put on the fenders first - it will be very difficult to get to the bolts...
Also you will want to align the door gaps first and then hang the fenders after that. |
04-19-2010, 02:21 PM | #4 |
Start from the rear and work forward on any sheetmetal sawp. That way you can set the back door gaps, then the bottom/top, then you can install the fenders withough adjusting the doors!
