Old 04-19-2010, 03:01 PM   #1
jht3rd
Is this a good deal?
A 2003 5.3l pullout with 4l65E trans, wiring harness and computer for 700.00
It's missing a couple of coil packs and the transmission is for a 4 wheel drive.
The man bought it to put in a street rod but never did. It has set in his garage for 4 years and he has never heard it run. Supposly only has 35000 miles.Is this a good price? I would like to put it in a 68 c10 2wheel drive. What do you think?
jht3rd is offline   Reply With Quote
Old 04-19-2010, 04:36 PM   #2
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
Re: Is this a good deal?
If its complete and runs its a good deal...(pan to throttle body)
Cole Trickle is offline   Reply With Quote
Old 04-19-2010, 04:37 PM   #3
dan42
dan42's Avatar
Sounds like a very fair deal. I'm not sure about the tranny and the four wheel drive issue. It would be a good amount of work to put into our trucks unless you're already an accomplished mechanic.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-19-2010, 04:46 PM   #4
clinebarger
The transmission will be a 4L60E. The transmission will need to be torn down to install a 2wd output shaft, you will also need a VSS reluctor ring, 2wd extension housing, 2wd VSS sensor. Sounds like a good price
clinebarger is offline   Reply With Quote
Old 04-19-2010, 04:50 PM   #5
Cole Trickle
C-10 Club Member
Sell the tranny and put the $$$ toeards a used 4L80
Old 04-19-2010, 05:24 PM   #6
clinebarger
Not really needed behind a 5.3 in a 1/2 ton truck. 4L60Es are not as bad as everyone thinks.
Old 04-19-2010, 05:51 PM   #7
Cole Trickle
C-10 Club Member
4l60 will handle 400hp if not abused. Great tranny for bolton/cam power(they don't like blowers much)
If I could find a 4l80 for a couple hundred more that will be $$$ well spent as I tend to forget to drive easy and stop at 400hp....lol
Old 04-19-2010, 08:16 PM   #8
jht3rd
Since it's been sitting for so long is that hard on the engine? What would it cost to convert the trans to a 2 wheel drive? Anything else to look for when I
go look at it?
Old 04-19-2010, 08:55 PM   #9
clinebarger
go look at it?
The engine will be fine (teflon seals, neoprene gaskets) If the injector rail wasnt drained/engine wasnt ran out of fuel you might have some gummed up injectors, take them out & soak them in sea-foam. Leave the injectors & coils unhooked when first cranking the engine too build oil pressure.
If you supply the parts a good trans man whould charge you 100 bucks.
Old 04-19-2010, 09:11 PM   #10
Ackattack
Ackattack's Avatar
I would sell that tranny and find a 2wd 4L60E. The 2wd tailshaft extensions are spendy.
Sounds like a good deal to me.
FYI, find some used stock coil packs for cheap. The MSD ones are $$$ and offer no gains over the stockers.
Ackattack is offline   Reply With Quote
Old 04-20-2010, 12:12 AM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
See if you can pull the vin out of the computer prior to buying and run it through Carfax. I bought a 2003 5.3 w/ 4l60E 60,000 miles for $750. Carfax told me it was a 2000, 4.8 225,000 miles and from a stolen truck. Because your right at core price I would take a chance.
dwcsr is offline   Reply With Quote
Old 04-20-2010, 09:48 AM   #12
jht3rd
Can you tell a 5.3 from a 4.8 just by looking at it? Is the vin printed on the engine or the computer that I can write it down? Probably will go look at it this weekend and i want to be prepared. Thanks for all the help you guys have given me
