Old 04-19-2010, 03:32 PM   #1
my70chevyc10
my70chevyc10's Avatar
P/S Belt
Anyone know what belt number to use on my truck. The po just used 1 belt for the power steering from the grank pully to the pump and it rubs on the water pump pully it looks like it is sopose to go around the crank and water pump pully then to the p/s pump like a triangle.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
Old 04-19-2010, 04:39 PM   #2
rsavage
rsavage's Avatar
Re: P/S Belt
On my trucks, the PS belt runs only from the crank pulley to the pump. Where are you on your PS pump adjustment? Perhaps the belt is too short or too long by a smidge?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-19-2010, 05:41 PM   #3
cdowns
cdowns's Avatar
Re: P/S Belt
if you can post a good pic someone will be able to tell if the ps pump is mounted correctly
only one short belt going crank to ps is normal
