Old 04-19-2010, 06:50 PM   #1
David67
David67's Avatar
Axles
How do you put lugs into the predrilled holes of the axles without going to a shop?
David67 is offline   Reply With Quote
Old 04-19-2010, 08:07 PM   #2
JimKshortstep4x4
Re: Axles
I use the stock nut as a puller by turning it backwards. Several washers are stacked up on the stud which are coated with grease which will help you turn the nut. After sticking the stud in the hole, installing the washers and starting the nut a quick hit with the impact wrench will pull the stud in place.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
