Old 02-09-2003, 12:27 AM   #1
rkkeith
Anyone got Vent window Repair tips??
Does anyone have any vent window repair tips. I bought a set with good chrome and I am trying to replace the rubber and it is giving me a hard time. Has anyone done this successfully and remained sane???? I would appreciate any advice. Thanks.
rkkeith is offline   Reply With Quote
Old 02-09-2003, 10:51 AM   #2
pierce
pierce's Avatar
It's been awhile but you need to drill out a few rivets, there are replacement rivets that come with a little tool for this repair. Once you remove the rivets you can replace the rubber easily.
69 GMC 1 Ton Longhorn
37 Chevy Coupe
pierce is offline   Reply With Quote
Old 02-09-2003, 03:10 PM   #3
Hutch
Hutch's Avatar
You have to drill out the rivets that hold the glass to the window channel.
I left the pin that the glass pivots on because mine were in good shape.
When you are reassembling use good rivets that fit well also your rivet gun will need a narrow nose to fit into the channel to get a good seat.
If you have the old channels practice on them first as you will get better at it as the more you do it.
Then when you put the assembly back into the door the question will be does the bottom rubber go on the inside of the door or overlap to the outside. You will understand this a lot better when you get to this point.
Have fun and let everyone know how it goes.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 02-09-2003, 09:14 PM   #4
jhow66
jhow66's Avatar
Ok Hutch do they or don't they? Just finished mine.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-09-2003, 11:41 PM   #5
rkkeith
Thanks guys for the tips. I am going to work on them this week some. Man, its hard to restore a truck and work a full time job....
Old 02-10-2003, 12:35 AM   #6
Hutch
Hutch's Avatar
jhow66,
I am really not sure about the way to install the lower rubber on the vents.
Each one of my doors was assembled different when I disassembled them.
When I put them back on I went with the rubber to the outside, my thinking was that this would help to keep the moisture from getting inside the doors.
But the more I look at them I think that they originally were ment to install to the inside.
Which would provide a smoother look.
I have asked this question before and most people seemed to think either way whichever you prefer.
This would be a good question for the experts on these trucks.
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Old 02-10-2003, 12:49 AM   #7
jhow66
jhow66's Avatar
Thanks--put mine on outside also. Guess we will have to wait for what the experts say.
Old 02-10-2003, 11:17 AM   #8
oldcarbuff
I put new rubber around mine, but didn't drill out the rivets. I left the original divider post rubber in place, as mine was in good shape. On the triangular piece, I slit it (from the inside) to clear the lower pivot and slit it at the top to get all the way to the top. I use a large pair of linemans pliers to gradually squeeze the rubber into the grooves all the way around. When I was finished, I put a little drop of sealant into the two small slits I had made.
I didn't have the little flat rivets and my window pivoted just fine, so this method worked fine for me (note: it was a major pita. Took me about three hours to do the two windows). It fits up fine and stops the wind whistles I had before. I have not opened and lcosed them much since that time, because it SNOWS EVERY DOGGONE DAY lately.
OCB
oldcarbuff is offline   Reply With Quote
