Resident of Here
Calculated the mileage.
Well, we drove to Wilmington yesterday in the burb and filled it up when we got there. Then drove back doing 75-85 in Cruise. Came back and filled it back up, calculated gallons+miles. 22MPG! #7500 4x4 27 y/o Suburban getting 22mpg. Awesome.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Re: Calculated the mileage.
Wow, I almost got 13 once
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
With my leaky carb, I get 8.1. Yay!
BMW & ASE Master Certified
sounds like your speedo is incorrect. If your speedo is correct, im sure, almost positive GM would be putting that technology in all of their trucks and suv's. With my speedo calibrated to the tires and rear gear... 5.3, 4L60, 3.42rear gear,tuned for gas mileage 5600# on the sticker, cruising at 75 from houston to florida I think I might have seen 21... in my opinion, no way is your suburban getting that kinda mileage.... unless your running a low compression engine with turbo(s)...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
I have a 86 C-10 with a 350 and i am geting 9.1... Man i need a new tranny haha
Did you miss the sig line on having a 6.2 diesel?
1987 R10 6.2 700R4 3.08's I get 22+MPG all the time, 24-25 with mixed city/rural/highway driving, I bet I would get 27 if I only drove at 55mph with no stops. The 6.2 makes lousy power but is very efficient 1800-2500RPM. The key is the diesel, GM doesn't put this in trucks because we all wanted 400hp instead of 195HP and great MPG. And now they have to add EGR and soot traps which kills you. And while turbos pump up the power they also increase fuel needs dramatically. My 5400# 5.3 4l60E cab and a half 99 3/4 ton gets 15-17. My 72 402/375hp 1 ton Longhorn got 9.5. My 90 454SS got 9.5.
1987 2 ton ![]() 1982 ![]() Dad's 1981 ![]() Plus a mess o' tractors |
#7 | ||
Resident of Here
yeah i did miss that... i did see the 3.73 though... well good job on the mileage.. well alteast i was on to the right track on the low compression and turbo part... lol
Happy to be here
![]() Join Date: Mar 2000
Don't feel bad, I did the same thing. I was about to throw the BS flag then remembered he had a diesel.
#10 | |
Resident of Here
Nice numbers. I hope to see that in mine. I doubt I will as the smallest tires ill run will be 35's but will gear it right. I should get around 18 from what I've seen.
Throw some pics up of the Burb. |
Resident of Here
No pics. When I get it detailed next, I'll take some pics. Rare paint scheme too.
#13 |
dam, haha im laughing at myself you said diesel and i still thought of a gaser... haha, now that you said the high compression , im like :doh:... im just gona stop replying to your thread.... it will work out better that way
