Old 04-19-2010, 10:04 PM   #1
MJN
MJN's Avatar
front driveshaft measurment needed
Need the length of a stock front driveshaft from a '73-'80 truck with Dana 44 front axle, SBC, 465/205 combo. Needs to be a CV joint at the transfer case and also have a front yoke output not the flange style.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 04-21-2010, 09:12 PM   #2
MJN
MJN's Avatar
Re: front driveshaft measurment needed
even a weld to weld measurement of the tube would be helpful....anyone??? Just need to know what length I need if I find one at a swap meet.
'17 GMC Yukon XL
VCCA member #58596
Old 04-28-2010, 08:43 AM   #3
msgross
msgross's Avatar
anyone able to help? sorry...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 05-01-2010, 04:57 AM   #4
84 400
Sb 400 club
84 400's Avatar
It will be the shortest one something like C-C Length: 24 5/8?????. If you find one that is 27 then that is for an automatic//203 combo and will be too big. Look on ebay for someone selling one and that should get you the measurements just remember the range is from 1973 to 1977. 1977 was the change over year. Also if possible look for one off a k20 as it will have the heavyer duty slip splines.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 05-01-2010, 11:25 PM   #5
MJN
MJN's Avatar
Well, after everything I had a brand new one made. 26" yoke to yoke. 13" tube weld to weld. I did find a stock one with a 13" tube but the slip joint was longer than the driveshaft I have with a 14" tube. The shaft with the 14" tube had a 6.25" slip joint and the 13" tube had a 7.5" slip joint, so side by side they were the same overall length and the slip yokes cannot be swapped. The 465/203 front shaft is the longest I've seen with a 16" tube.
I know when they changed to the saginaw (flange) style, my trucks are all too old for that. The only one I've owned new enough for the flange was my '79 Suburban and I swapped it out for an older trans and t-case. Not sure if others had run into this or not, no one seemed to know what length a stock driveshaft is supposed to be.
'17 GMC Yukon XL
VCCA member #58596
Old 05-02-2010, 04:05 AM   #6
84 400
Sb 400 club
84 400's Avatar
I don't remember all the specs off hand but I know a th350 with a np203 in the Saginaw flange style is 27 inches center to center. When i swapped my np203 for an np205 i new i had to get a different drive shaft. So i bought one out of a 1979 k20 that was stock for a 465/205. however this was to short and strached out. I knew offroad it would pull apart. So i went to my local driveline shop and was happy to find i could buy a longer slip yoke from spicer at a 1/2 of the cost of a new longer shaft.
Also the 12 shafts are a finer spline but actually weaker then the 3/4 and 1 ton splines. If your on the hunt for a spline look for a 3/4 ton version as it will have the same 1310 u joints and the HD splkines
1985 C10 LWB Sold
