power antenna
i am wanting to put a power antenna on my truck but in the stoc location but all the power antennas that i found need about 8-10 inches of clearance below the fender. I was wondering if i would be able to drill a hole directly below the stock mounting hole large enough to fit the antenna through without affecting anything else on the truck
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Old member
I don't think it will work because of the way the inner panel is for the fire wall. take the cowl off and you will see what I mean. But hay anything is possible with a enough money and engineering.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
L.E.D. Freak
I'd like to do the same thing to the Blazer only french it at the same time. I think I'm going to do it were the stock gas tank filler neck is.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
Old member
This is how mine looks. I placed it on the passenger side. I wish now I had taken the tank out when I did this, because now I have to fill that hole up also.
Better late than never
![]() Join Date: Dec 2001
I was thinking of installing a hidden antenna, in the headliner or somewhere else. Has anyone done this?
1970 C/10 SWB Stepside |
I am a Referee of life.
KEH, mine is mounted under the dash crossways.I just built a mount and bolted it in then ran the wire to it.It probably doesn't pick up as well if it was on the fender but I have cassette and just copy what I want to hear off of CD's at home so it doesn't bother me if I pass thru an occassional "dead" area.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
PanelDeland,
I may do the same you did, but after thinking about it, I'm sure that I will also get a satelite radio system. They sound like a great deal, but I haven't talked with anyone who has one...
D.U.F. Member
I once saw someone french the antenna like the picture shows, but instead of just a round recessed area, they did it in the shape of a bowtie. Looked pretty sweet.
MEMBER OF THE DISCS UP FRONT CLUB '72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt '68 C-10 4spd (not running) '79 C-10 LWB Mild 350 '80 Caprice Classic, 2-dr '97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto |
![]() Join Date: Oct 2001
Nice truck Andy. What antenna did you use?
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
Old member
It's just a aftermarket you buy at NAPA. Just wire it up to a hot and ground and to power lead from radio.
Seņor Member
Harada and others offer a remote motor antenna. It's basically the same as their standard power antenna but the motor is on a flexible shaft so you can mount it curved to one side. Jaguar XJ's have this type as well.
Kenneth
