67cheby
![]() Join Date: Sep 2008
any tricks /pic of installing vintage air sure fit system
just ordered my system havent received it yet just asking for tips , or pics of the install, sure fit system with smooth firewall, Where did you run your lines out??
Re: any tricks /pic of installing vintage air sure fit system
Even though I used Classic auto air if you go in my build thread there are several picts of how my a/c lines were ran with a smoothed fire wall.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
67cheby
what kind of mount did you use , i assume some kind of lower mount ?? looks very clean
Under Construction
here is a link to Jesses install of a vintage air kit:
http://www.67-72chevytrucks.com/vboa...d.php?t=249479
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
67cheby
thanks for that link read the whole thing, great pointers
See my build thread below my signature. My truck came with Old Air aftermarket A/C that was originally mounted on a blank-off plate that came with the A/C. I welded in a smooth plate and smoothed the firewall in this area. My truck is not an A/C cab but I plan on adding round A/C ports in each lower dash corner (through a 2" hole, not under). I'll then put some center ports into a built-in console.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
![]() Join Date: Apr 2010
Just Wondering....
Just wondering why you chose the VA system over the OA system. (OA=OldAir, VA=Vintage Air) I'm quite sure the VA system is a quality system but I do really like the electronic OA controls that come in the kit.
With the electronic controls, there are no cables to route and adjust. It is a plug and play deal. OA also comes with the in-dash vents for those (and there are many) trucks not equipped with factory AC. Just cut the holes and use the vents supplied with the kit. One last item I like about the OA system is the better serviceability to components. What I mean is that smaller assemblies can be replaced as needed over time rather than large expensive assemblies. Again, I am just curious about your choice...wondering if it is hidden better or some other advantage I am not aware of. I don't have AC in my truck yet...but it is the first thing I will do when I get out of this hell-hole called Iraq. After much research about the manufacturers out there for our beautiful trucks, I liked the OA better. Just MO. |
67cheby
i wanted to use my factory controls in the dash, can you do that with the old air ??
Yes, there are kits available that utilize your factory controls. $1095 with indash vents included for trucks W/O factory AC.
I am also reviewing the VA thread. Lots of good info there for virtually any install for our trucks. |
