Old 04-20-2010, 05:57 PM   #1
84 400
Sb 400 club
84 400's Avatar
ever seen this winch mount?
http://images.craigslist.org/3n13p83...6675a6145f.jpg
http://images.craigslist.org/3nd3o83...15c25c1dff.jpg
I saw this on CL and was wondering if it would work on my 77k10. Looks like it puts the sinch up high out of harms way. I wonder if my 8274 would fit. I also wonder how strong of a mounting point it is. Appears to have only 4 bolts holding it on to the front of the frame rails?? Any input would be very helpful
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-20-2010, 07:59 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: ever seen this winch mount?
Its only going to be as strong as those four points. It looks like its the same as the bumper mounting holes. I'd go with some pretty good sized grade 8 bolts and you should be good to go.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 04-20-2010, 10:22 PM   #3
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
usually on a full sized bumper you would see 2 additional mounts that tie into the (front) leaf spring hanger,to the left and right bumper (which this doesnt have). The only other weakness i can spot is how high it sits the winch. In theory its good to have you winch mounted as high as possible to keep it out of harms way but it seems like if you were stuck in a mud hole you would want your cable to pull the vehicle slightly upwards as well as forward... but then again I guess normal height is only about 6" lower than that... run it if the price is right..
Eturnit3 is offline   Reply With Quote
Old 04-21-2010, 01:56 PM   #4
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
the only dis-advantage is how high the winch sets on the mount, it puts excess stress on the frame horns and trys to twist them off the fraima friend had one back in highschool and didn't put the tie-in brackets on and pulled the front bumper and frame horns off the first time he got stuck and used the winch
Tex_50613 is offline   Reply With Quote
Old 04-21-2010, 11:26 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea x2 Had a buddy that had pretty much the same setup n the same damn thing happened to him! Will have to see if I still have any of those pics lol!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
