Old 04-21-2010, 07:55 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Fuel Gauge test
How can I check my fuel gauge to see if it still works? I am going to hook up an aftermarket fuel guge this weekend and I need to know how I can test the stock fuel gauge to see if it needs replacing. If the aftermarket gauge doesn't work then I would lean towards the sending unit but as it stands right now the stock gauge does absolutely nothing.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-21-2010, 10:46 AM   #2
Burlinator
Just Another Crazy Canuck
Burlinator's Avatar
Re: Fuel Gauge test
ohm meter on your sender should tell you
0=empty-90=full
1985 454/465/205, 38.5x11-16BOGGERS
soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI
Burlinator is offline   Reply With Quote
Old 04-21-2010, 02:40 PM   #3
softballnrd27
Re: Fuel Gauge test
Can I get to the sending unit w/o dropping the tank? Should I just remove the bed?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 04-21-2010, 03:00 PM   #4
Slofarmtruck
Re: Fuel Gauge test
I just asked a similar question in another post regarding changing out my gas tank. The majority consensus was its easier to remove the bed to get to everything.
Slofarmtruck is offline   Reply With Quote
