04-21-2010, 01:41 PM | #1 |
60-66 Hood Hinges
60-66 Cowl Mounted Hood Hinges $265
By Porterbuilt Street Rods It was only a matter of time before we dialed in our cowl mounted hood hinges for the 60-66 C10s. We have been offering a re-locator bracket for the factory hinges for a few years now, but they limited the overall tire diameter to 27”… that kept the wheel selection to a 20” rim. These new cowl mounted hinges will allow the frame-rails to touch-down without tire to hinge clearance issues. The Install is simple and straight forward, and requires some cutting of the cowl panel, welding a mounting pad to the rear hood hinge support, and of course… careful measuring! Here’s a quick installation write up on the hinges… look for a better write-up in the near future! The hinges need to be mounted 45.625” apart (that’s 45 5/8). Find the center-line of the cowl and make a reference mark. There will be mounting hole real close to center where the cowl panel screw mounts. Once the center-line of the cowl has been found, measure out towards the fenders 22.8125” (that’s 22 13/16”) and make a reference mark. This will be the center-line location for the hood hinge pockets. It will be necessary to cut a hole in the cowl so the hinge pocket can be installed. Make sure you leave a small lip on the front of the cowl for strength, and also be careful as the cuts will get close to the wiper mechanism. Make a template of the hinge pocket mounting holes with posterboard or paper and transfer the pattern to the cowl. Drill the holes and cut the slit for the hinge arm. I find it easiest to drill two holes at the top and bottom of the slit and then connect them with a cut-off wheel. Install the hinge pocket and hinge arms (there is a RIGHT and a LEFT side. The bottom of the hinge pockets are angled to follow the slope of the cowl). The pocket will be installed first, and then slide the hinge arm through the slit. Check for clearances and make adjustments where necessary. Install all mounting hardware. Just like our 67-72 hinges, there is a mounting pad that needs to be welded to the hood brace on the underside of the hood. The heat from the weld WILL NOT affect the exterior paint. Just as with the cowl panel, you will need to find the hood brace’s centerline. There are a couple of holes in the brace that will be near dead-center. Make some measurements to verify this. The hood mounting pads’ centerline needs to be the same as the hinge pockets’…45.625” (45 5/8) once centerline is found, make a mark. Measure out 22.8125” (that’s 22 13/16”) and make a reference mark on each side. This reference mark will be the centerline for the hood mounting pads. The back of the mounting pad will measure 1” off the rear edge of the hood brace (see picture below). Verify this measurement to be as close as possible. Careful measuring during this portion of the install will make things much easier! Set the mounting pad in place on the hood, verify measurements, and clean the surface before welding. Tack the pad in place and test fit the hood. Once the mounting location of the hood pads has been verified and test fit, remove the hood and fully weld the pads to the under-hood brace. Install the cowl panel before the hood goes on for the final time. There is ample fore-aft adjustment for the hood to set the gap at the cowl, and there are also shims available (if needed) to adjust the height of the hood at the cowl.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! Last edited by PBFAB.COM; 05-17-2011 at 05:26 PM. |
04-21-2010, 02:45 PM | #2 |
Re: 60-66 Hood Hinges
Yes! Awesome Nate. I am currently saving for my dropmember and these are a very necessary addition, what are the brackets on the fire wall?
68 Chevelle 396 4spd-sold needed money when I got married Current build-66 C-10, 350, 4spd, disc brakes, CPP 3-5 drop, saving for Porterbuilt drop member |
04-21-2010, 03:04 PM | #3 |
Those are the old re-locator brackets for the original hood hinges.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-21-2010, 05:24 PM | #4 |
Keepin it old school
Like I said in the other thread I am so stoked that these are done..
I will def be placing my order in the next couple weeks. |
04-21-2010, 05:27 PM | #5 |
Member of the longbed union.
I would place an order but I'm broke. Send me the cad file and I'll make them. haha
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
04-26-2010, 01:47 PM | #6 |
///Relaxed Atmosphere
i know who i will be calling in the next day or so
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
04-28-2010, 08:08 AM | #7 |
Porterbuilt,
The stock hinge mechanism lifts the hood upward more than in an arc. Does the stock front hood latch work with this arrangment? Thanks |
04-28-2010, 12:48 PM | #8 |
You are correct, the hood swing will be at a different arc than the factory hinged hood.... fortunately, the factory latch and safety catch still works just fine.
07-29-2011, 07:31 PM | #9 |
how will the hood be kept open? just that you still don't offer the gas shocks for the 60-66... or am i missing something... jaja, plan on buying it soon, hopefully...
My truck spends more than my wife, is that normal? |
07-30-2011, 07:37 AM | #10 |
1961 crewcab
nice setup
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
07-30-2011, 09:16 AM | #11 |
07-30-2011, 11:18 AM | #12 |
The hood stays open with a prop rod, or man power with this set-up. We will be coming out with a gas assist upgrade that is compatible with these hinges. It will not be the same style as our 67-72 version, as these hoods are just too heavy to be supported that way.
Nate
07-30-2011, 11:32 AM | #13 |
Registered Loser
Can't wait for the upgrade. I feel like I need a nap every time I open my hood
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
06-04-2012, 01:24 PM | #14 |
Is it possible to keep the stock A/C box with these hinges? I'm assuming not because it looks like the left side goes in the same place as the A/C box.
07-08-2012, 12:41 PM | #15 |
Any idea when the strut assist hinges will be available?
09-20-2012, 02:56 AM | #16 |
no kidding!
Bryan 1966 SWB BBW "SICKT6" Accuair|Porterbuilt|Bodied|Shaved|Z'd|350 with minor goodies|5 lug|front disc|3.73 rear|CPP power steering/brakes|few more goodies| thanks to C10Clubapparel |
