Burb gas tank in truck
will a burb gas tank fit under the bed of a pickup truck?
i notice the aftermarket tanks made for burbs hold 5-10 more gallons of fuel compared to the aftermarket truck tanks (19-21 gallons)
1970 2wd ![]() ![]() ![]() |
Grandpa in the rustmobile...
Re: Burb gas tank in truck
im almost positive, either blazer or burb, they may be the same, i THINK I have a blazer tank in bluegoose
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Six in a row makes it go...
![]() Join Date: Mar 2009
My brother bolted one into his '68 C10 short fleet. I still have the tank if you want a picture of it. I think it is 25 gallons.
The one he got was an original out of a junkyard 'burb.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce Last edited by Shaky; 04-21-2010 at 06:14 PM. |
a picture would be nice to see
standard 1/2 ton burb tank is 21 gallons.
ya i was looking at the CCP 26 gallon (burb) instead of the truck 19 gallon
Here is a 31 gal burb tank in a `70 C20.
thats looks nice what year burb tank is it?
does the filler really come out the passenger side? (man that sucks) i like driver side better oh wait thats the spring shackle sticking up so is the filler on the driver side?
1970 2wd ![]() ![]() ![]() Last edited by nrb's70gmc; 04-21-2010 at 08:40 PM. |
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
how does it mount? top/bottom of the frame?? or inside top/bottom of the frame rail???
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Mounts to the frame with metal straps but I have seen them mounted inside the frame with out straps with a little trimming of the lower frame rail..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
It mounted to the bottom of the frame. The holes you see in the side flange lined up with holes in the frame. He just put some big 'ol bolts in and drove it for years. No straps came with it and he didn't use any.
#13 |
Out of the carpool lane.
I'm using a '73 burb tank. I think it's around 26 gal.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#14 | |
