Old 04-21-2010, 03:38 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
*LS/GenIII swappers* A/C part numbers inside
I put together a list of parts needed if you are swapping to a GenIII/LS style engine and wish to retain the LS's A/C compressor in it's original location without notching the frame. I also threw in some part numbers of other things like the condenser, accumulator, etc in case you either need to or want to replace those.
I got the system charged today and it works awesome, so if this is the way you are planning/wanting to go, it works great!
Keep in mind - the misc part numbers for things like the condenser, accumulator, and so forth are specific to my 85; however, they will most likely be the same for 81-87. 73-80 will almost definitely have different part numbers. If you are doing this on a 73-80, confirm the fitting sizes on the receiver dryer/accumulator, evaporator and the condenser before ordering your fittings.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-21-2010, 04:20 PM   #2
k10shortbox
Re: *LS/GenIII swappers* A/C part numbers inside
so you used the factory bracket and condenser? This will save a ton of money, thanks!
k10shortbox is offline   Reply With Quote
Old 04-21-2010, 04:32 PM   #3
glock35ipsc
Everything was original to the truck (albeit new replacement parts) except the compressor (came with the 5.3) and the hoses (I made those). The compressor mounts to the 5.3L just as it did in the donor vehicle.
Note in the pic the trans cooler lines are running out underneath the A/C idler pulley. Those have been rerouted inside the frame rail using SS braided hose. The steel lines were getting pinched right there.
Bob
Old 04-21-2010, 08:25 PM   #4
SBTork
Garage wrench
SBTork's Avatar
Great work again Bob. Maybe this should be a sticky, just a thought.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-21-2010, 11:11 PM   #5
SatisTraction
thanks for the list, it will come in very handy!!
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 04-22-2010, 07:22 AM   #6
Cherub
Cherub's Avatar
Yea i think there should be an lsx swap sticky. So we can condense all the information in all these build threads.
Cherub is offline   Reply With Quote
Old 04-22-2010, 09:26 AM   #7
glock35ipsc
Thealien has done a LOT of work in a thread he started, compiling tons of links and other info on the swaps. If it isn't already in the FAQ section, it should be. I'll see about putting this list in that thread too, and check on the FAQ part of it too.
Bob
Old 04-22-2010, 06:37 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Why in the @#$#@ would engineers move the compressor down by the frame?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-22-2010, 06:48 PM   #9
Pyrotechnic
Pyrotechnic's Avatar
I imagine it was to keep the lines down low and out of the way, and most likely so they could run the A/C on it's own belt off the crank pulley. That way if the compressor locks up, it's not going to shred the serpentine belt and leave you stranded.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-22-2010, 08:51 PM   #10
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Bobs the man.
--Josh
Old 04-22-2010, 09:06 PM   #11
rare86
Extended cab fanatic
rare86's Avatar
thanks for the list
If it has a motor, it has my attention.
rare86 is offline   Reply With Quote
