04-21-2010, 05:56 PM | #1 |
will 15x8 wheels with 4or 4 1/2 bs
will they fit over front and rear disc brakes? which bs is better to keep tire in the fender? thanks guys
04-21-2010, 06:19 PM | #2 |
Watch out for your cornhole !
Re: will 15x8 wheels with 4or 4 1/2 bs
Sure, they will fit fine. The 4 inch backspace is the same measurement as a stock rally so that gives you an idea of how they look under the truck. The 4.5 inch backspace will tuck under the truck a bit better if you lower it.
04-21-2010, 06:20 PM | #3 |
67-72 parts collector,…
Up front a 15x8 with a 4" bs. is the most backspace you will fit up front without having wheel issues. (wheel contacting the lower a-arm) You may even have to trim the lower a-arm with a grinder. Calipers sometimes need grinding also.
If you would go up too a larger (17"-20") diameter wheel, more backspacing can be used. The rear should be fine with 15's and a 4"-4.5" bs.
04-21-2010, 06:29 PM | #4 | |
