Old 04-21-2010, 09:51 PM   #1
munchieu
What years do i need for donor
What years do i need for donor for my 66? 73 thur 87 or 86? i thought it was 87, but i looked at an 87 and the engine cross member is welded to the frame and i thought i heard it was bolt up or did that stop at 86? can i swap upper and lower a arms from 87 to my 66?
munchieu is offline   Reply With Quote
Old 04-21-2010, 09:55 PM   #2
burbguy
burbguy's Avatar
Re: What years do i need for donor
I was told 73-87 as well...
Shawn
1966 short fleet 230 I-6 three in the tree (daily driver)
1966 short fleet big block th400 (building slowly)
1972 c10 3 door suburban 350 th350 (building faster than slowly)
2004 F250 power stroke (not dependable enough to be a daily driver)
2005 Kenworth T-800 Heavy Haul tractor (that's my true daily driver)
burbguy is offline   Reply With Quote
Old 04-21-2010, 09:58 PM   #3
munchieu
well i just looked at my 66 and no way will the 87 i looked at work as far as upper a arms. maybe the truck is a late 87 and they changed stuff
Old 04-21-2010, 10:09 PM   #4
munchieu
or do i just use everything but the 87 upper a arms. this 87 truck is complete, running with TBI 350, 4 speed auto, ps,pb,ac, disc brakes. all the goodies i want to swap into my plain drum brake 6 banger 66.
Old 04-21-2010, 10:25 PM   #5
burbguy
burbguy's Avatar
doesnt the whole cross member unbolt and drop out? If so take the whole enchilada, steering box and all...even get ahold of captain fab for one of his power brake booster brackets, and take that too...
Shawn
Old 04-21-2010, 10:30 PM   #6
munchieu
the cross member looks welded to the frame and upper a arms are conected to the top of the frame
Old 04-21-2010, 10:36 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Here's the thread that has become the standard of information on front suspension and parts swaps:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-21-2010, 10:42 PM   #8
munchieu
thanks! so im guessing the truck i looked at must be 88. cuz there is no way i can unbolt the cross member
Old 04-21-2010, 10:43 PM   #9
burbguy
burbguy's Avatar
wasnt 88 the start of the rounded body style..? If so you need the last of the square body's
Shawn
Old 04-22-2010, 12:37 AM   #10
Captainfab
60-66 Nut
That truck would be considered an '88
You could use the spindles, rotors, calipers, etc. on your truck. You would just need to change your C10 lower control arms for a set of C20 lower control arms. There are details in the thread than Markeb01 linked to. It's the one about converting to 6 lug disc's using factory parts. The spindles on the truck you're talking about are the same as long as they are 5 lug or thr 6 lug light duty 3/4 ton. But be aware that the rear ends on the '88 and up trucks are a bit wider than the '71-'87's and a lot wider than the '63-'70's.
Old 04-22-2010, 12:11 PM   #11
munchieu
Thanks for the info! my 66 is a c-20. this truck im looking at is a 6 lug 3/4 ton. i dont know what to do. will te power stering from the 88 work? i kinda wanted to keep my truck 8 lug, but this truck i'm looking at is only $500
Old 04-22-2010, 12:24 PM   #12
munchieu
another question for ya. can i use 8 lug rotor in place of the 6lug from the 88? and should the 8 lug rotor be from an 88 also?
Old 04-22-2010, 02:27 PM   #13
Captainfab
60-66 Nut
If you want to stay with the C20 8 lug, then you'd be better off finding a '71-'87 C20. On the '88 and up the spindles for the 8 lug hubs are different than the spindle for the 5 and 6 lug hubs. The 6 lug hubs are for the light duty 2500 (7300# GVW) whereas the 8 lug hubs are the standard duty 2500 (8500# GVW) And no the steering box from the '88 will not work on your truck. The '88 and up trucks have a much wider frame with the steering box on the inside of the frame. The '87 and earlier trucks have the steering box on the outside of the frame.
Old 04-22-2010, 02:32 PM   #14
munchieu
I think i'll keep on looking. Thanks for the info!
